View Poll Results: nnnn
fseg 0 0%
grsg 0 0%
Voters: 0. You may not vote on this poll
Old 09-25-2004, 11:55 AM
69CamaroRSSSLover 69CamaroRSSSLover is offline
Thumbs up 4WD not working -- SEE NEW FIX HERE!
I found this while searching for a cheaper alternative to the vacuum actuator - I own a repair facility and do a lot of business with a local used truck dealer. We are currently working on -- you guessed it -- a 1998 blazer that will not engage 4 hi or low. While I cannot personally use it this seems like a reasonable alternative to the vacuum system for private owners. I sincerely hope this helps some of you to correct the problem and relieve your stress. I personally own a 96 (2WD) blazer but I understand. I had the cooling system and DexCool issue with mine.
Any way, Good Luck to all!!!!
CamaroLover
http://www.eastcoastoffroad.com/posi/#sseries
Old 09-25-2004, 08:11 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 4WD not working -- SEE NEW FIX HERE!
So are oyu talking about a cooling issue or a 4x4 issue?
