Old 09-24-2004, 09:35 PM
MFG003 MFG003 is offline
Car Problem!! Plz Help!!
(93-civic-hb-gsr swap) when i drive my car, it tends to boggle like it's choking and goin to die. Just today i drove it on a fairly warm day and my car would idle funny. the RPM goes high then low and to 0 at some point. i have to step on the acceleration pedal to keep my rpm high and avoid my car to shut down. anyhelp will be great!!
Old 09-24-2004, 10:46 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Car Problem!! Plz Help!!
A bad IAVC and TPS are common problems with swaps. Actually, a bad IAVC is common with B series period. Do you have vacuum leaks. If no vacuum leaks, then check your IAVC if it is clogged. This should be your first step in diagnosing your problem.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 09-25-2004, 02:18 AM
what is a IVAC? how can i get for the vacum leak? Can it be the ignitor? or spark plugs?
Old 09-25-2004, 04:27 PM
AF - Advisor
A bad IAVC
I meant IACV (Idle Air Control Valve). It sits behind the throttle body. It has two hoses going in and out of it. What you need to do is, pull it out and check if the screen is clogged or torn. If it is, then replace it. $150 at autozone. maybe $20 on ebay used, but as long as the screen is not blocked or torn, it will be fine.
Your rpms jumping up and down followed by engine dying out sometimes is a common symptom of a bad IACV.............common among hondas. Usually followed by a code also, but, ive never experienced codes with a bad IACV.
Old 09-25-2004, 04:40 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
I had the same problem and it was my IACV. Also maybe you need to adjust the TPS? Most likely its either of them 2. Go to the junkyard and ask them if they have the IACV. Or search on www.thepartstrader.com , www.hondaclassifieds.com
Old 09-25-2004, 10:32 PM
I hope you guyz are right, i'm goin to look in to that ASAP. shit i hope it's nothing major. Do I have to take any precaution before installing IAVC. THX AGAIN
Old 09-25-2004, 10:35 PM
mellowboy's Avatar
No its safe. Just be sure not to loose your bolts.
Also my car jerk jerks like your stalling a car in first gear, Tha's how it feels when i drive . Could this IAVC cause that?
Old 09-25-2004, 10:40 PM
mellowboy's Avatar
I'm not too sure about that. Like it bogs? Well fix those 2 things mentioned by superbluecivicsi and then if it does keep bogging...could be electrical problem. Its really hard to tell.
mellowboy's Avatar
I'm sorry ... i mean mechanical.
Old 09-26-2004, 04:04 AM
yeah it could be that i hope. cuz it's borthering me for a LONG ASS time and i just wanna get this thing fix, So i'll try to replace teh IACV and see how that goes, Thank for the help
