Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-24-2004, 07:21 PM
atv_babe atv_babe is offline
2002 Dodge Ram--P1491 fault code
Can anyone help me figure out what this code is and how to fix it wihtout paying big bucks? We took the truck to autozone and they scanned for the code. P1491 is what they came up with but said it was an OEM code and couldn't tell us anything else. All help is appreciated.
Old 09-24-2004, 09:21 PM
moparboy99 moparboy99 is offline
Send a message via AIM to moparboy99
Re: 2002 Dodge Ram--P1491 fault code
check and make sure you gas cap is on tight
Old 10-02-2004, 08:49 PM
Dman2003's Avatar
Dman2003 Dman2003 is offline
Did you fill the tank with the motor running
Old 10-10-2004, 10:03 AM
hotrod314 hotrod314 is offline
Thumbs up Re: 2002 Dodge Ram--P1491 fault code
I had the same code and same prob i found the code was for my a/c condensor fan i found my fuse was blown. i put a new fuse in and dissconnected the battery for a min and the code went away that was my prob maybe it will help u.
Old 10-10-2004, 01:27 PM
Thanks for the replys. We had the Dodge dealer hook it up. It was the a/c fan and a fuse.
Old 11-13-2004, 07:08 PM
Dodgepower76 Dodgepower76 is offline
Send a message via AIM to Dodgepower76
hey I have the same problem with that code.. I got 2 different sayings.. one person said it was Radiatior relay switch and then the other person said it was a Secondary Switch Solenoid Circuit Malfunction. So what is the deal? Any ideas? thanks
Old 11-14-2004, 08:08 AM
jrmcx jrmcx is offline
Don't know if this helps
http://autorepair.about.com/library/...bl399a-lib.htm
Old 11-14-2004, 01:26 PM
hundahunta hundahunta is offline
p 1491 cooling fan radiator relay circuit!
Old 01-08-2006, 08:57 PM
kaliman198117 kaliman198117 is offline
Re: Re: 2002 Dodge Ram--P1491 fault code
I have the same problem but can anyone tell me what the hell es Secondary Switch Solenoid Circuit Malfunction? i mean i don't know if is a a/c because i don't even use it. Any help would be appreciated i did got the code p1491 on the scanner but i have no idea what to do. Somebody help me please, and thank you
Old 01-15-2006, 03:53 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
P1491
SYMPTOM
P1491 - Radiator Fan Control Relay Circuit
POSSIBLE CAUSES
An open or shorted condition detected in the radiator fan control relay control circuit. This includes PWM solid state relays. The manufacturer doesn't provide any further information regarding this code.
NOTE: This vehicle is not equipped with Radiator Fan Control Relay, however the vehicle does have a Condenser Fan Relay.
http://dodgeram.info/tsb/2002/08-015-02.htm
Old 01-15-2006, 11:00 AM
1thunder 1thunder is offline
there is a service bulletin for this problem #08-02-03 consists of replacing condensor fan shroud & motor and reprograming the pcm if not done fuse will burn out randomly worst in cold weather
Old 08-18-2006, 01:40 PM
ringlett1 ringlett1 is offline
Smile Re: 2002 Dodge Ram--P1491 fault code
Boy is the internet great or what, you guys directed me straight to my problem, being the blown fuse.Thanks
Old 03-19-2007, 08:59 AM
eric Ram eric Ram is offline
Question Re: 2002 Dodge Ram--P1491 fault code
Can anyone tell me where this fuse is? Which one?
Thanks.
Old 03-21-2007, 06:52 PM
it's in the pdc {fuse box} under the hood it's a 25 amp fuse at the centre row at the very end towards the engine
Old 03-28-2007, 07:40 AM
OK, I replaced the fuse and disconnected the battery but I still have the check engine light on and the P1491 code, any suggestions. THe truck has almost 90K on it. If there is a tSB on this, wouldn't this be covered since it is a design flaw, and probably should have been a recall.
