Go Back   Automotive Forums Car Chat > Buick > Century
Old 09-24-2004, 07:12 PM
y2icon's Avatar
y2icon y2icon is offline
Send a message via AIM to y2icon Send a message via Yahoo to y2icon
how much fuel pressure is a 93 century.....
how much fuel pressure is it suppost to have?
Old 10-05-2004, 10:30 PM
captain93 captain93 is offline
Re: how much fuel pressure is a 93 century.....
good question. i'm wondering how the fuel system regains pressure at all after replacing my fuel pump. any help would be greatly appreciated.
Old 12-10-2004, 03:11 PM
tbaxleyjr tbaxleyjr is offline
Re: Re: how much fuel pressure is a 93 century.....
35-45 psig with regulator vacume hose attached, 40-50 psig with regulator vacume hose discionnected and plugged.
The fuel pump has an electric priming circuit which starts the fuel pump as soon as the ignition switch comes on.
Once the lube oil pressure reaches 6 psig, the oil auxiliary contacts on the oil pressure sending unit pulls in the fuel pump relay for normal system operation.
The fuel pressure regulator controls the pressure by bypassing fuel back to the fuel tank if it is not needed to feed the injectors. under start-up, the injectors are calling for very little fuel and there is little vacume calling for the regulator to bypass thus the pressure increases (similar to blowing into a drinking straw with the end blocked)
Old 12-10-2004, 06:35 PM
Re: Re: Re: how much fuel pressure is a 93 century.....
thanks for the reply but it ended up being the inertia switch. not really a switch but i had to unplug and replug a wiring harness inside the trunk to reset the fuel system. works like a charm
