Old 09-24-2004, 05:13 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Is there anyway to tell if timing belt is going?
Since I'm the third owner of my car, I have no clue if the timing belt has been replaced. The last owner said they've never replaced it but have only had it for a year and then I bought it last year. Is there any way to tell if the timing belt needs to be replaced? Are there any symptoms to tell with?
It's just my car is getting really fucked up lately and hasn't been running to well.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 09-24-2004, 05:18 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: Is there anyway to tell if timing belt is going?
well anytime i buy a honda thats an old car and i dont know when the timing belt been changed i do it myself and know that its good to go....
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 09-24-2004, 05:45 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
i dont think wear and tear on the belt is too noticeable to determine age
i'd replace it as soon as u can just to be safe. when i bought my civic the last owner put a sticky note on the manual with the mileage to change it which was nice
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 09-24-2004, 05:50 PM
Shaguar47's Avatar
But there has to be some symptoms of notice?
Old 09-24-2004, 05:52 PM
icE_x's Avatar
jus asked dad, said no noticeable symptoms - the only symptom you'll see is when it breaks and ur engine quits lol
Old 09-24-2004, 06:01 PM
Shaguar47's Avatar
Thanks for the tip. I appreciate it. Alright then, how much has anybody paid to get the timing belt replaced? I'm getting three paychecks this october and am already getting:
- New tires
- New rotors
- New spark plug wires
- Suspension alignment
- Wheel balancing
- PCV valve
- Spark plug seals replaced
If it's im price range then I'll add it to my list.
Old 09-24-2004, 06:23 PM
papdetomaso papdetomaso is offline
Don't know a price, but have them do the water pump while they are in there. It will save you some money down the road...good luck
Old 09-24-2004, 06:26 PM
Shaguar47's Avatar
I'll guess I'll get the mechanics at the local garage to check it when they do my seals and gasket. Will they charge me more to check it since the head will be off when they're replacing the seals?
Old 09-24-2004, 06:41 PM
Shaguar47's Avatar
And just out of curiosity, when you miss a tooth on the belt, what happens?
Old 09-24-2004, 07:55 PM
slave slave is offline
BANNED
1 tooth, probably bugger all.
JDM IS NOT LHD
My other car's a Porsche, but today I'm in a hurry.
Old 09-25-2004, 12:38 AM
Hybrid1990crx's Avatar
One tooth off is nothing. When I got my new Si it was a tooth off. I just fixed it yesterday. It will just make your car slow in the high rpms and it wont want to pull at all.
Old 09-25-2004, 11:41 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: Re: Is there anyway to tell if timing belt is going?
man, i'm seeing a lot of bad answers given out all over the civic/crx forum
"jus asked dad, said no noticeable symptoms - the only symptom you'll see is when it breaks and ur engine quits lol"
is one of them, sorry to say.
you can inspect the belt. look in between the teeth. if you see minor cracking it's a worn belt and you should consider changing it soon. if there are major crack i would fix it immediately.
here are the timing pages to give you an idea if its something you would like to fix yourself...
Cylinder head/ valve train section:
http://www.binghamtonlife.com/manual...alve_train.htm
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-25-2004, 12:26 PM
Shaguar47's Avatar
Ami, your the best
Old 09-25-2004, 06:37 PM
civicwithawankel civicwithawankel is offline
I just got my car going again about a week ago after my timing belt snapped a while back. As for symptoms it will start out with timing going off (broken teeth but belt still holding) giving uneven/unusual power and engine speed, surging, etc, possibly a code 8 meaning "TDC Timing Fault"... in the worst case scenario if enough teeth are stripped and the timing gets way off your valves will be making a strange metallic banging sound while they're getting smashed by the pistons... very bad...
if you're lucky like I was, and the belt snaps and the camshaft stops with all the valves closed then the valves will be ok but the car will just die, it might surge very erratically (hard accel, then lag, accel, lag...) just before it goes, and by the time you think 'wtf is happening?' it will just stop firing and freewheel like if you ran out of gas, probably with a few warning lights on also. A timing belt is cheap insurance, even if you can't replace it yourself go get someone else to do it for you.
Old 09-25-2004, 08:29 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
and if you're unluck like me when shit breaks you'll bend every friggen valve in the head
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
