Old 09-24-2004, 03:53 PM
LT1 Kayker's Avatar
LT1 Kayker LT1 Kayker is offline
Send a message via AIM to LT1 Kayker Send a message via Yahoo to LT1 Kayker
Vacuum Test
Ok this is a dumb question, but I have done a compression test on my 89 Chevy C1500 and they were all around 100/150 which was perfect. Now I want to do a vacuum test on it, but every time I tried I couldn't get it to work. Anybody have directions or a website that could show me?
I want to do the test because it bogs (I don't know what to call it, but it seems to totally die, as in sounds like it shuts off, if I gun it, like it skips a power stroke or something) more than a fat lady running to the pisser from a stop, and from slow or idle if I give it more than 1/2 gas. It will ocassionaly (as in most of the time) not seem to rev up right when I try to go from a stop sign. I start going and it seems like the revs sit at a certain spot for like 3 seconds then I have to floor it and 2 seconds after that it will either downshift and go, or it will just shoot the revs up high on the current gear. I replaced my cap and rotor, and put in new plugs and my uncle and I totally took it apart and put in new gaskets and cleaned it up like 8 months ago when I baught it. Any help PLZZZZ!?
89 Chevy C1500 - Over 305,000 miles on her but still going strong.
Cut off cat/straight pipe.
Flo-Pro muffler. (Flowmaster soon)
Dual 3" tips.
custom intake.
chrome valve covers.
uhhh and im poor so thats all haha.
Friggin truck costs more to keep alive than I do. (4ishMPG no joke)
Wait, let me get this straight...Your honda has 1.6 liters, but my bottle of Mountain Dew has 2!?
Old 09-26-2004, 12:24 AM
Rbraczyk Rbraczyk is offline
Send a message via AIM to Rbraczyk
Re: Vacuum Test
http://www.users.bigpond.com/ergoff/vac2.htm
Call me your savior, and do fill me in on anything you find, i have the same exact problem with my blazer. almost when going slow and you let off the gas it almost dies.
Old 09-26-2004, 01:08 AM
mrrob mrrob is offline
Are you trying to See if you Have?
Do you think you may have a Vacuum leak causing your (BOG).
EG : Intake / TBI or Vac lines in general?
Mr.Rob
Lic Mech Auto/Truck/Trailer Ect...
Old 09-26-2004, 12:49 PM
LT1 Kayker's Avatar
I guess so. Thats really the only thing I can think of that would be the problem. My timing is off a little, but not bad enough to cause a stroke miss or kink out or whatever. I did the compression test and it came out almost perfect. Re-gaped the plugs and got a new cap and rotor with old new wires. (Never used or opend the box before) I replaced the PCV valve...A vacuum test is really all I have left to check it with. Oh, and sorry to be a nitpicky weiner, but I have a chart that shows what the readings from the vacuum gauge means, and diagrams and all like from that site, it's just the test in general I can't figure out how to do! I feel retarded asking because I should know how but I just can't get it to work. I put it into one of the throttle body Constant pressure thingys, but I think it's either the IAC or some of the valve cover hosing I made causing the problem. I can't really get the IAC port to not leak, even when I take it out and jam towels or/and my fingers in it while I test. I will talke a picture of my engine with the air cleaner off and stuff to show you the hosing I had to do when I ordered cheap, cheezy valve covers that weren't even symetrical when my dad comes back with the camera monday.
BTW, I can't find a vacuum tester for FI engines anywhere around where I live. I tried Target, Wal Mart, Fleetfarm, Checker, and Pep Boys...Checker was the only place that had one and it was $66 or something. I heard from my shop teacher that you can get them for $12 at Tools for Less or something but I don't know of one around here. Any suggestions on where to find one so I can just do the test at my house myself? Thanks for the help and info though, I will be so happy once I fix this problem.
Dual 3" tips.
custom intake.
Old 09-26-2004, 06:25 PM
Re: Vacuum Test
Plug the sucker into the PCV valve hookup at the front of the throttle body.
Old 09-26-2004, 06:38 PM
LT1 Kayker's Avatar
Alright, i'll try that tomorrow in my shop class. Thanks for the help.
Dual 3" tips.
custom intake.
Old 09-27-2004, 03:57 AM
Re: Vacuum Test
Thanks, and def post results, im anxious to hear what you have going on.
