Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 09-24-2004, 02:54 PM
GT500916's Avatar
GT500916 GT500916 is offline
Banned
Send a message via AIM to GT500916
engine light came on..
Engine light just randomly came on, then i changed the clutch and put the tranny back in and it went back off again, then after a couplke days it came on again WTH?!! is there a common problem on 240s that would cause the engine light to turn on?
Anyone had same problem post what you did to fix , thanks
Old 09-24-2004, 03:06 PM
vsiev vsiev is offline
Send a message via AIM to vsiev
Re: engine light came on..
check the code. You won't know what to fix unless you know the problem. Go to the ecu and count the blinks when you go to mode 1
Hiya...
Need a FSM? Hit me up I'll send it to ya for FREE!
I only have the 91-98 240sx, s13 ca18det, and s14 sr20det FSM
Sorry no 89-90 yet....
Mods:
Tein Flex with EDFC
Hotshot Header
R32 GTR Seats
Advan SA3 16x7 16x8
Apexi Dual N1 Exhaust
Silvia Front End Conversion
Digital Climate Control
Nismo 2-Way LSD
Injen Intake w/ CAI
Old 09-24-2004, 03:26 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
http://www.240sx.org/faq/articles/ecm_codes_doch.htm
Old 09-24-2004, 05:33 PM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
the light came off because when u worked on the motor etc you probably disconnected the battery, atleast I hope you did........ disconnecting the battery for a length of time can be a nig rig way of clearing codes....
when u started the engine again the light was off because the code was not set yet, eventually something happened that the computer did not like and it set that code, coulda taken 2 minutes, 5 hours, 3 days... what have u.......
Old 09-24-2004, 06:08 PM
GT500916's Avatar
Banned
ok , how do i get to mode 1? the only thing that it says in my manual is that the engine light might be on because something to do with emition so dont drive faster than 45 miles per hour or some crap like that haha... how do i get it to blink, please be more specific thanks.
Old 09-24-2004, 07:22 PM
Grenyaer Grenyaer is offline
Send a message via AIM to Grenyaer Send a message via MSN to Grenyaer
check the link JSpec gave you. !
Old 09-24-2004, 09:40 PM
on the ecu there is a turn knob that you have to access with a flat head screw driver. have the ignition set to on and turn it clockwise to the end, wait like 2 secs and then turn it back counter clockwise till it stops(don't force it at any time, it can only go so far). Once you do that, you will be on mode 1 and watch the blinking lights. Long blinks will be consider 10's while short, fast blinks will be consider 1's....example: 3 long blinks, and 2 short blinks will be consider 32...look that up in the manual(which is the egr problem and it isn't just the egr...it is the system) Hope that helps.
Hiya...
Mods:
Tein Flex with EDFC
Hotshot Header
R32 GTR Seats
Advan SA3 16x7 16x8
Nismo 2-Way LSD
Injen Intake w/ CAI
Old 09-25-2004, 11:30 PM
lucki17 lucki17 is offline
nig rig, ha ha, thats great.
