Old 09-24-2004, 11:38 AM
kgodwin3 kgodwin3 is offline
91 lumina euro headlights
how do i go about changing the headlight on my lumina i cant seem to get the lens off...whats the deal?...
Old 09-24-2004, 12:29 PM
newfslumina newfslumina is offline
Re: 91 lumina euro headlights
If you are just trying to replace the bulb all you have to do is lift the hood and there will be a plastic flap above the headlight. Just lift it up and you will have access to the bulb...just turn it counterclockwise and pull it out and unplug the bulb
Old 09-24-2004, 03:21 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Don't touch the new one's glass, or it will last about a week.
Old 09-27-2004, 03:33 PM
Corkscrew Corkscrew is offline
Not too long ago, we tried an experiment trying to get a bulb to blow. In stages, we touched it as much as possible, put vaseline on it, put motor oil on it, and it wouldn't blow. Just smoked. This was on bright setting. Even tried higher voltage. Finally wrapped it in aluminum foil and it ballooned out some, but still didn't blow. But we didn't run it for a week.
Old 09-27-2004, 04:14 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
isn't that funny how you can TRY to make one blow and it won't, yet the slightest mis-handling of one you intend to leave in will cause it to go "POOF"
