Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 09-24-2004, 11:29 AM
MomoMax98 MomoMax98 is offline
Cali Knock Sensor
i just got my knock sensor and i cant find the fuckin thing under the car...does anybody have and pictures or a link to site with pics of the install...ive gotten one on the org but the instructions swallow...
My Ride
Old 09-25-2004, 10:20 AM
THT THT is offline
Re: Cali Knock Sensor
Year? Should be just under the IM.
~THT
Some people call it an obsession; I call it my Maxima.
Old 10-03-2004, 04:25 PM
mikesilvia415 mikesilvia415 is offline
Send a message via AIM to mikesilvia415 Send a message via Yahoo to mikesilvia415
i just replaced mine on a 96 maxima...if the car is facing you its on the right side under the intake manifold...Chilton says to take it off if you want to replace it. I did it with out but my hands fit under the IM. your's may not
(try replacing it ONLY WEN THE CAR IS COLD unless you like the ER)
the KS is held by (1) 8mm bolt
its possible your stick you hand under the IM and unscrew it with a very short open hand wrench with the tip at an angle
if it seems stuck just find a better possition and try again.
make sure not to lose the bolt or have it fall through.take new sensor and bolt it in preferebly with torque wrench. the torque should be 15-20lb but double check.
removing the air intake box and the mass air flow sensor should also help becaus eit should give more room for working
I dont suggest using a flexible tip w/ a 8mm tip and an extension like most people suggest because unce the flex tip is under the IM the extension will pushing up against the IM (there is only about 3-4 inches max height clearence under the IM)
and if you plan on doing it w/o taking the IM off get some band-aids ready.
