Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 09-24-2004, 09:04 AM
hungt1999 hungt1999 is offline
Wipers on my 1996 Corolla run so slow
Hi,
The wipers on my 1996 Corolla are running so slow now, even at the highest speed, it takes about 2 secs to wipe once cycle.
anyone has the same problem? what can I do to fix ?
thanks
Update 9/28/2004:
- I removed the wiper motor, it runs great without the wipers mechanism attached. Therefore the slow movement of the wipers must be caused by something else.
- I removed the grill that covers the wiper mechanism, the grill runs across the bottom of the windshield, near the firewall.
- it turns out that the accumulation of dirt and corrosion cause a partial jam of the wiper mechanism (consists of two pairs of pivot&arm connected to the motor)
- now runs fine!
Old 09-24-2004, 09:54 AM
93rollaracer's Avatar
93rollaracer 93rollaracer is offline
Send a message via AIM to 93rollaracer
Re: Wipers on my 1996 Corolla run so slow
motor might be going. car-parts.com toyota dealer or ebay might have a new one...pop that in and it should be back to normal
Proud member of DAMM: Drunks Against Mad Mothers
Originally Posted by vinnym86
Metalheads: 93rolleracer
crazy sons of bitches who get hammered, break shit, and scream. yeah, they're pretty cool. right up to the point when they lynch a black guy.
Old 10-13-2004, 04:43 PM
thehoot thehoot is offline
I had the same problem with my 95. I pulled off the motor and moved the swing mechanism around quite a bit. It works fine now (same old motor) I think the mechanism just needed to be loosened up. If you can figure out how to get at the swing arm (attached to the morot) try lubeing it up.
