Go Back   Automotive Forums Car Chat > Ford > Contour
Old 09-24-2004, 08:43 AM
wtlee3 wtlee3 is offline
1995 contour transmission jerks
I have a 1995 Ford Contour SE with an ATX that has 140,000 miles. Since about 90,000 I have been experiencing an intermittent problem with the computer and transmission. Every so often the transmission will start shifting hard, it lunges(hard jerk) when it shifts in and between the forward gears. When I check the codes it brings up a transmission code and when I clear it it takes care of the problem for a few weeks to a few months until it pops back up. I was told that it might have been the main computer, so I replaced it, thinking that there was a glitch in the old one, but even with the new computer the problem still occurs. Is there a sensor or chip or anything in the transmission that could cause this random code to be sent? Any help would be appreciated. Thanks!
Old 09-24-2004, 10:47 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
when was the last time the trans fluid has been flushed?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 09-27-2004, 12:38 PM
Re: 1995 contour transmission jerks
Probably 100,000 miles...Sweet 96'
Old 09-27-2004, 12:39 PM
Re: Re: 1995 contour transmission jerks
It happened before and after the change, just not as frequently
