Old 09-23-2004, 11:14 PM
tyko909 tyko909 is offline
Send a message via Yahoo to tyko909
How to ween the rich
I have a 2g tsi that is running too rich. I know that because my exhaust keeps getting tha sheezy black buildup and my exhaust kinda smells like gasoline. my mods are as follows,
turbo xs boost manual controler
turbo xs Blow off valve RFL open air
wanna be fpic also known as a OBX adaptor and a 4.5 inch cone
3 inch exhaust from the turbo back
new o2 sensors up and down stream
new iridium plugs
and MSD 8.5 superconductor wires.
Anyone know how to get it to run alittle leaner. Where I live high octane gas is alittle expensive and its making my tanabe muffler look like an apc
Who needs speed when you push 155.8 dB.... I do!!!
6Bolt cyclone, 16g turbo, AWD, and a 5 speed
Old 09-23-2004, 11:38 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: How to ween the rich
recirculate your bov. do a search on dumping your bov and you'll find the reasons behind it, or check the FAQ
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 09-23-2004, 11:40 PM
kjewer1 kjewer1 is offline
AF - Advisor
EVen when I run as lean as 13:1 I still get that crap in the ehxuast. Except that on leaded fuel the deposit is white. No way around it, turbo cars run rich. 9.5:1 from the factory The RFL will only make you a touch rich when shifting, unless it is leaking. Any boost leaks after the airflow sensor will result in a rich mixture.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-24-2004, 02:45 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
to recirculate the BOV (like my GReddy S), u just plug a hose from the only open outlet from the BOV to anywhere into the intake pipe, correct? I did just that and it seems to run a little less "jerkier" between shifts, but the BOV still sounds as loud as when i was venting... did i hook it up right? because i hear recircualting it should cause the BOV to be not as loud.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 09-24-2004, 06:49 AM
Thanks
I think I am gonna recirculate the bov now. thanks for your help... I cant wait till my other motor is done.... I am stroking a 6 bolt and trying to put about 25 psi of boost to it. that should be a fun run minus the lag. I am eventualy gonna try to get into the low tens. heres to hittin the mark.
Old 09-24-2004, 06:51 AM
AF - Advisor
It will still be loud recirculated. If you dumped the big outlet back into the intake pipe before the turbo, yes you did it right. As long as there are no leaks.
25 psi on a stroker isnt going to get you in the low tens unless the car weighs very very little. In my 2g (3300 with me in it) 27 psi has been good for low 11s. With really good launch/driving, I could hit a very high ten. Low tens requires a large increase in power.
Just for fun guys I did some math last night. Two cars running 135 mph in the quarter, one 3300 pounds like mine, the other 2800 pounds. Mine requires ONE HUNDRED more WHP to hit that mark. Gay.
Kevin Jewer
Old 09-24-2004, 11:41 AM
Shpyder's Avatar
Moderate moderator
Holy shit. 100 WHP more? thats nuts....so its gets exponentially more expensive per extra marginal reduction in 1/4 mile time.
Old 09-24-2004, 12:33 PM
I will be using a venom fully programable
nitrous kit also that gasses
btwn 2500 and shuts off at 5500 in each gear.
Water injection, and cryo.
we are expecting to be in the 650+ hp range
. Remember, A DOUBLE STACK WINS THE TRACK ....
Oh man, think about how many motors I will blow in a year...
I think I am gonna need more sponsors....
