Old 09-23-2004, 09:59 PM
mikemechanic's Avatar
mikemechanic mikemechanic is offline
Question Studio 27 high tech decals
What makes them "high tech" as opposed to their regular decals. Thanks. Mike.
Old 09-23-2004, 10:19 PM
scaleracecars scaleracecars is offline
Re: Studio 27 high tech decals
There is no carrier film. You peel off the clear tape like material from the decal after they dry so they look like a dry transfer.
David
http://www.scaleracecars.com
Old 09-23-2004, 10:38 PM
Thanks David. Much appreciatted.
Old 09-24-2004, 05:25 AM
hueb_s's Avatar
hueb_s hueb_s is offline
BTW: Most (if not all?) decals of Museum Collection are high-tech decals...
The decals cover mostly the same subjects as Studio27 ones, but are also a bit cheaper.
Best Regards,
Steffen
Old 09-24-2004, 06:39 AM
freakray freakray is offline
AF Modelrater
In addition to Mike's question then, if you peel off the carrier film, how do you get high tech decals to conform to complex surfaces?
AF User Guidelines
Old 09-24-2004, 07:13 AM
Re: Re: Studio 27 high tech decals
Your guess is as good as mine. I have heard of removing the film the rewetting and using solvents. I would not buy them for a car with a lot of problem areas.
Old 09-24-2004, 07:28 AM
AF Modelrater
It's not a car with a lot of problem areas, but there is one spot where the decals have to form around a vent and this makes me nervous/wary.
I'll have a look to see what you have in stock David as a possible substitute in the event that something does go wrong
AF User Guidelines
Old 09-25-2004, 01:05 AM
hirofkd's Avatar
hirofkd hirofkd is offline
You apply high-tech decal as you do with normal water-slide decal, and let it dry. Then, use a weak tape to gently lift the carrier film.
Hiroaki Fukuda
