Old 09-23-2004, 09:16 PM
mxz1034 mxz1034 is offline
Send a message via AIM to mxz1034
Exclamation Spark Plug Wires/distributor Cap Help!!!!!!!
I have a 91 eclipse 4 cylinder non turbo that i was gettign ready to sell. It was having a problem so i tried to fix it. when cold the car would start then die out, this would happen for a few tries then it finally would saty idiling and run. So i thought the problem was in the distributor cap. So i unplugged the spark plug wires from the cap and tooom the cap off. i found nothign wrong so i put the cap back on. I then found out that the wires had to go on the cap in a certain way. Well i don't know the order and the car won't start now. Please somebody help me!
Old 09-24-2004, 09:35 AM
riff22 riff22 is offline
Re: Spark Plug Wires/distributor Cap Help!!!!!!!
Spark plug wire routing - if you removed your spark plug wires without paying attention to the routing, don't worry. On 4G63s, the spark plugs are numbered from the timing belt/driver's side - #1 is closest to the timing belt. The connections to the coilpack are 4123, with 4 being closest to the head. See this pic. Note that since 4G63s use a waste spark system that fires 1/4 and 2/3 together, you can also hook the wires to the coilpack as 1423 and 1432 and it will work fine. Note that wire #3 is longer than #4 - shortest to longest, they are 1243
Old 09-24-2004, 09:37 AM
here is the pic sorry, http://www.vfaq.com/images/Spark_Plug_Wires.gif
Old 09-24-2004, 02:40 PM
RSLaser RSLaser is offline
.....what distributor cap?
1991 Plymouth Laser RS
Only sat for a few years....
Old 09-24-2004, 04:10 PM
macder macder is offline
Send a message via MSN to macder
Yea, i though the 4g63 uses a coil not distributor
Old 09-24-2004, 05:09 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Let this be a lesson to you... he he he he
First rule of thumb... record wiring and really anything when fixing........ lol
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
