My Neon started to lose speed but would shift in to gear but, when stop it died and did not start again the battery is fine ,the alt. is fien the o2 bank 1 is has been replaced ,then i looked on here and kat womaen said it might be the fuse for the fuel pump so i looked . To my surprise it was the fuse 20 amp. But Now the it goes about 1-3 miles and the fuse blows . Can anyone help me !!!!!!!!!!!???????????
Re: 95 Neon Fuel pump fuse Blows
i had a 95 neon my fuel pump fuse blew 1 time when i was burning out i slammed second gear real hard and it just shut down. i replaced the fuse and it never happened again. check the wiring on ur fuel pump it might be grounding out.
my little sister drives a 94 neon that is doing the same thing, we replaced the fuel pump and the computer and the pump relay, we have the schematic out of the haynes manual and it shows nothing else on the circut, all of the wires are clean with no breaks that i can see, did you ever find the problem with yours????
Neons have 2 O2 sensors which are wired into the fuel pump fuse as well as well as the primary power to ecu. Allot of time the wires for the downstream 02, the one after the cat, cross the axle and break open and will blow the fuse. Look over the passenger side axle and there will more than likely be wires that are either partly warn through or even completely brokeken, replace them bind them all together with electrical tape then zip tie them out of the way. If thats not the problem, check the wires for the primary 02, but that unusual... of it keeps doing it your ecu wires might be messed up, check them and it all is good.... you more than likely need a new ECU
