Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-23-2004, 08:19 PM
Franky-5-Fingaz's Avatar
Franky-5-Fingaz Franky-5-Fingaz is offline
Send a message via AIM to Franky-5-Fingaz
Drilled or Slotted
aight for all you brake nutz... Cross-Drilled or Slotted Rotors...???? I persnally don't understand what the differnce is, they both disperse heat evenly across the rotor and they both last for a long while i've herd. Somebody help me before i make the wrong decision, because this whole month i'm gonna be into my brakes and pretty much my brakes only... you know.. safety FIRST.. haha
Thanks
Anybody up for a Race against a Pearl White 97' T-bird
PeAce
FW
a.k.a
Franky-5-Fingaz
Old 09-24-2004, 05:02 AM
MI-Thunderbird MI-Thunderbird is offline
Re: Drilled or Slotted
Hi there,
I changed my 96 T-birds rotors last year to cross drilled ones. I debated for quite some time since the whole thing cost me 500$, but now that I have them I am happy. The whole braking process is a bit different, you cannot just stomp at them anymore.You have to brake kinda light because they do stop at a dime.What I can tell you is that mine wear down very slow...no grooves or nothing yet, no brakedust whatsoever which is nice I do not have to scrub the rims with a toothbrush no more No noise, no nothing. My old rotors were so stuck on that we had to lightly beat them off. Just make sure you have the tool to compress the caliper otherwise it will be a big pain in the a..! Hope this helps, have a great day
Marija
Old 09-26-2004, 10:24 PM
Thanks... Ya in the shop at school we have the Ford tool used to compress the Rear calipers, as in the Front al lu need is a C-Clamp, but thanks for the info i think ima go with cross drilled, but i heard you cant machine cross-drilled rotors... is this true?
PeAce
FW
a.k.a
Franky-5-Fingaz
Old 09-28-2004, 03:19 AM
Honestly I do not know. While you are looking check out KVR's that is what I got. Just call and ask the place you want to order them from. Like I said mine were changed last year March and I would definitly recommend them. Have fun.
Old 10-05-2004, 01:31 AM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
This could be the stupidest question you ever heard, but I have no idea... I wanted to get some cross drilled/slotted rotors but couldnt afford them, so I had to get the regular old flat rotors... would it hurt to drill holes in those?
Old 10-09-2004, 11:30 AM
don't do that, im thinking their drilled and slotted like geometrically in place (if that made any sense) like you cant just go and drill holes in stock rotors it doenst work the same.
PeAce
FW
a.k.a
Franky-5-Fingaz
Old 10-09-2004, 10:54 PM
oh yeah, good point
Old 10-09-2004, 11:04 PM
igor@af's Avatar
igor@af igor@af is offline
Your friendly AF Admin
Send a message via ICQ to igor@af Send a message via AIM to igor@af
Having been in the motorsports industry myself now, I quickly learned that the issue of the rotors is not really debated anymore, with a clearly identifiable winner.
For racing purposes, most cars use slotted (non drilled) rotors to dispense heat and gas. The holes decrease the structural integrity dramatically, causing the cracking of the rotors.
For the street, considering the limited stress levels, there should not be any performance difference between the slotted and/or drilled rotors.
Both of these designs are intended to prevent brake fade, and I do not believe they affect the braking performance itself in any way whatsoever. As in, considering rotor/pad temperatures are constant, neither of designs has no effect on the stopping distance.
Welcome to the Revolution
Old 10-09-2004, 11:13 PM
I agree that it really isnt a big deal performance wise between drilled or slotted, but they are much better than plain rotors, any day. They stop quicker, and they look great, and produce less brake dust, which is great for people who like their car to look nice. I want the cross drilled and slotted rotors simply for the look and the brake dust , because my plain rotors leave a film of dust on my wheels after 2 days, and that sucks.
Old 10-10-2004, 02:45 AM
igor@af's Avatar
I doubt that drilled and/or slotted rotors can alleviate the brake dust issue. In my experience that depends much more on the type of pad I am using.
Again, I want to emphasize that as far as I am aware, drilled/slotted rotors do not affect the stopping distance of the car in any way.
Old 10-10-2004, 02:56 AM
thats the first time I've ever heard a negative opinion about drilled/slotted rotors.
Old 10-10-2004, 09:04 AM
cudaz101 cudaz101 is offline
Send a message via AIM to cudaz101 Send a message via Yahoo to cudaz101
It has been my impression that neither do any noticable improvments to improve braking performance.
If you want better brakes get a big brake kit with 13" rotors...THAT is gonna make the car STOP...hehe
Brad
Old 10-10-2004, 01:30 PM
igor@af's Avatar
Slotted rotors are a must have for racecars, but for street it's not really paramount. Drilled rotors are only for looks nowadays.
Even with a stock braking system, if you change to stainless steel lines, use good fluid, and get really good pads, you will notice an incredible difference.
Even with StopTech's Big Brake Kit on, when on the street, I use Axxis Ultimate pads, and they're ok, but in no way compare to the God status of the PFC 97 pads that I use on the track. These carbon-metallic pads are incredible. 60-0 should be under 100ft.
However, you can't really use these specific pads with many stock rotors. PFC 97 pads are so hard, that they are harder than many rotors out there, which means that if you have a rotor that cannot handle the pad, you will be shaving the rotor instead of the pad during braking.
Old 10-16-2004, 09:48 PM
Josnuff Josnuff is offline
I am questioning the stuff they are putting in these new pads since the scare on asbestos.
I have 12" rotors (stock) and am having a problem of overheating on my 66. Never had a problem like this with the asbestos
type pads
Old 10-19-2004, 08:01 PM
hmmm thankz for the info everybdoy, and the part with the overheating of the brakes.. that isnt regualr, unless you like to slam down on your brakes every stop you make. They might actually be rubbing against the rotor when you drive. I had that problem for a good hmm 2 days.
PeAce
FW
a.k.a
Franky-5-Fingaz
