Old 09-23-2004, 06:29 PM
nwoods29321 nwoods29321 is offline
Send a message via Yahoo to nwoods29321
Z24 Problems??
I recently got an 88 cavalier z24 convertible, 2.8L, 5 speed. It is in great shape form what I can tell but......
After the engine warms up, the oil pressure guage drops when it is idling, the the shifter seems a little stiff, and the steering seems a bit loose.
Anybody have any ideas as to what all could be wrong??
Old 09-24-2004, 10:38 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Z24 Problems??
teh low oil pressure at idle is normal for a high mileage car. The stiff shifter might be a shift cable needing lube, or low fluid in the trans. Make sure you add the right fluid, GM used two different 5speeds, and they use different fluid. The loose steering is either a worn out tie rod, or the bushings at the rack are bad.
Old 09-25-2004, 03:11 PM
update on the z24 problems
I still have not had the chance to check the shift cables but there is a bad bushing on the inner tie rod. I have a replacement bushing but I can not get the tie rod off the car to fix it.
