Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 09-23-2004, 05:46 PM
mcsteele72432's Avatar
mcsteele72432 mcsteele72432 is offline
Send a message via Yahoo to mcsteele72432
Question (Newbe) question about the comp thing below the dash?
I justgot my 1995 jeep grand Cherokrr loradeo and that computer thing or whatever its called keeps reading taillight failure but the taillights are fine ans something about 4x4 switch. can anyone help me b/c its getting annoying and my wife will not let me take it out or shut it up.
Old 09-23-2004, 08:29 PM
dedfrog dedfrog is offline
I just bought a 93 and it did the same thing until my electrical system ate caca. I do know that there is a "lamp outage module" inside the emergency fuel door on the left side in the cargo area, it might suck. I have not been able to troubleshoot mine since I had the other electrical problem, but after I fix that I was going to see if the bulbs on either side were the same. I am thinking it may sense an imbalance between the resistances on each side. just a thought.
Old 09-24-2004, 02:35 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: (Newbe) question about the comp thing below the dash?
Ok, the "REAR LAMP FAILUre" , everyone has this problem sometime in there jeep...lol
have someone start the jeep, turn your light on, and check for any bulbs out (I had this problem could not find any bulbs burnt out , I checked over them 3 times, check bulbs at night easier to see), have them hold the brakes in check the high mount stop light there are three bulbs in there make sure they are all fine, have them put it in reverse make sure both the reverse lights work, also check the 2 license plate bulbs make sure the are working.
ok my problem after looking for a bad bulb couldn't find one, dam it. light still on. then the next day I remembered about the license plate bulb was sure I would find it here, nope both are good. had a friend check my brake lights while i held the brake in, he said they were all good, put it in reverse nope they were good, so I found nothing.
Well after a few days of that annoying beeping, I decided to check the lights again one night when we went to the store, I had my g/f hold the brakes while I looked, and there it was one of the damn bulbs in the high mount stop light was out (Hummmm thought I had someone check that, shows how dependable some friends are when they are in a hurry to get to the trails to throw some mudd around), well anyways changed the bulbs and needless to say that was 6 months ago and all is good.
Check the High Mount Brake Light in the upper liftgate, this is prolly where ur problem is, make sure u look very carefully over all the lights.
Old 09-29-2004, 12:02 AM
Thanks that helped it was the 3rd brake light. Now if im can just get the check 4wd switch message to stop flashing and beeping.
Old 09-29-2004, 10:21 AM
that would be your 4WD Switch, u will have to have that checked out
Old 09-29-2004, 10:23 AM
I don't know of any test u can perform to make sure it isn't bad, but I am sure someone has had that problem and will help u, talk to DALE he knows it all, and he should be able to help u
Old 09-29-2004, 10:38 AM
dude75 dude75 is offline
What about the "coolant sensor bad" message? I have had this one for quite awhile. Had the coolant sensor replaced and this did not fix the problem.
Old 09-29-2004, 10:41 AM
is there coolant in the reserve tank? DUMB QUESTION, but sometimes it's the simple things that are hard to find.
never mind I thought u were referring to the Low Coolant flashing
Old 09-29-2004, 11:47 AM
No problem. Was thinking that might be the problem or the coolant level sensor was bad, but the level sensor has gone off when the coolant has been low and after I filled the resovoir it went away. Took it to the dealership(they were the ones who said I had a bad fuel pump) and they were not able to recreate the problem. Recreate the problem? The sensor says bad on the VIC. I paid $98 bucks for nothing. Only Jeep dealership in Chicago, there service is not too good.
Old 10-29-2004, 09:56 PM
CapeFear562 CapeFear562 is offline
quick question, when the coolant sensor was replaced did they disconnect the battery cable and reset the computer. I have seen it happen before. Just a thought
