Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 09-23-2004, 04:43 PM
PatHeat PatHeat is offline
Unhappy Clutch not working
I recently installed a new 2.8L engine (long block) into my 1985 Bronco II. While I had the engine out, I installed a new clutch disk, pressure plate, pilot bearing, and release bearing. After getting everything back together and running, went to take it for a test drive and it would not move… I can shift in and out of any/all gears with out depressing the clutch peddle. There is no noise or grinding coming from the transmission. I bled the clutch, got a good bit of black fluid out at first and continued to bleed it even after clean fluid was coming out. This did not have any effect on things…???
Any suggestions?
Thanks
Pat
Old 11-01-2004, 09:21 AM
twoeighty twoeighty is offline
Re: Clutch not working
Still Need Help or Ideas, I had similar problem, eMail
""Attention 1985BroncoII-StillNeedHelp "" [email protected]
