Old 09-23-2004, 04:57 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
how do you know if your car is running lean?
Just as the title says... how do you know? I just changed my plugs and the old ones had a rust colored deposits on them but the electrode looked pretty good... as in not worn heavily...
Would the best way to find out is to have the engine thrown on a diagnostic machine?... not the autozone one but at a shop
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 09-23-2004, 08:24 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: how do you know if your car is running lean?
Best way is a wideband. Dyno shops use them. If you have a local dyno that has a deal like 50 bucks for 3 pulls (luckily you have a FWD) it might be worth a shot if you're really concerned about it. Plus you'll get some dyno numbers. If it is really lean, the wideband will show you that, and show just how lean you are. Thats what I Would do. A wideband kit is 3-400 bucks.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-24-2004, 10:45 AM
riff22 riff22 is offline
u can run it hard then while its hott take a plug or plugs out and look at them if there white there gettin hot and ur not gettin enough fuel. If there golden brown then ur good
Old 09-24-2004, 02:57 PM
AF - Advisor
Doesnt always work unless you shut the motor off at WOT But thats the general idea.
Kevin Jewer
