Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-12-2002, 07:35 PM
adamty1 adamty1 is offline
steady on airbag light
1995 maxima with a constant on air bag light, tried the door reset procedure and checked the fuse, anyone know where the harnesses are for the air bag system so i can check to see if one is loose, the light never flashed, just a steady on, thanks
Old 02-13-2002, 08:30 AM
NJMAXSELTD NJMAXSELTD is offline
Steady on light means your airbag system has a failure and is not operating. If the reset procedure doesn't turn it off, something has definately failed. Only a certified Airbag tech. (at your dealer) will be able to work on that system. Don't play around with it yourself.
Old 02-13-2002, 04:59 PM
Ravq Ravq is offline
I second that!
Stillen kit & grill, Stillen Type II spoiler, KYB AGX/Progress, 19x8.5 ADRs w/Toyo Proxes FZ4s, ...........
Old 02-13-2002, 09:39 PM
irvine78 irvine78 is offline
Send a message via AIM to irvine78 Send a message via Yahoo to irvine78
Re: steady on airbag light
just bring it back to the dealer...i think airbag system carries a 10 year warranty...if i'm wrong..still bring it...don't try to do it urself..u might set it off, or it might not deploy when u need it.
Maximadriver.com 2DMAX of Jan/Feb/March
Check out my new homepage!!
http://www.cardomain.com/id/irvine78
mods:Stillen/Premier custom intake, Stillen y-pipe, Stillen front strut tower bar, Stillen rear sway bar, Stillen touring front lip, Stillen side skirts and rear valence, GReddy Evolution cat-back, MSD In-line fuel pump, 2 B&M fuel pressure regulator set at 45psi with VDO read out gauge, Unorthodox racing UDP, Custom 8puck racing clutch/pressure plate, 100shot NOS, Eibach springs, KYB AGX shocks, 300ZX TT front calipers, 12.4inch 3000GT VR-4 cross drilled/slotted front rotors, custom rear superslot rotors with AXISS metal master pads, SS breaklines, red painted calipers, Joshua Tree carbon fiber dash kit, Pacesetter short shifter with MOMO knob, aluminum RAZO pedals, panasonic head unit, Alpine amp and single 12" JL sub, autometer air/fuel, oil pressure guages, Gunmetal Gray 18x7.5 AXIS SE7ENs with 225/40/18 Falken tires/19x8 WORK ESPERIO IIs with 245/35/19 Yokohama AVS Sports, front/rear clear corners, factory fog lights, factory spoiler and 00-01 SE tail lights, AE headlight conversion, JDM style yellow Raybrig blubs up front/rear, APEXi RSM.....shoot...did i leave something out?
Old 02-15-2002, 04:07 PM
bobo_80 bobo_80 is offline
Exclamation
go to ur dealer RIGHT AWAY!.......something wrong with the sensors!....
i had the same thing.....anda they <NISSAN<....replaced it with a emergency order for the sensors....took one day....and free of charge....
...when the airbag light is on, the air bag is set not to go off during accidents.....so, do it now...!!,or <ASAP<...
