Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 09-23-2004, 05:05 AM
william e smith william e smith is offline
Question 1987 monte carlo 305 350 swap
will a 350 work in place of 305 without much problems,
Old 09-23-2004, 10:44 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 1987 monte carlo 305 350 swap
it would be an easy swap, as long as both engines are of similar year. If both are carburated, externally, they are identical, so it should be a very simple swap. The only possible snag I know of is the flywheel and harmonic balancers. The 305's normally use a 7" balancer, which is not compatable with 350's. Some 305's had a 12" flywheel, most 350's use a larger one (13.84" I believe). Other than those two issues, it should be a painless swap.
Old 10-07-2004, 05:22 PM
tim1950 tim1950 is offline
Go to www,montecarloss.com for complete instructions for this swap
