Old 09-23-2004, 12:05 AM
JaggedFel JaggedFel is offline
Talking Low rpm problem
hey, my 2g gs shudders a lot under load when its under 3000 rpm. i know all the easy stuff, like the plug wires are all on, etc. - but the plugs look good, there's no visible leak in the intake system, and the vacuum line isn't off or anything. does anyone know how to check to see if my mass flow sensor or throttle position sensor is working? those are two of my main diagnosis', but if anybody has any other ideas, please let me know, i love my dsm i hate to see it not run right
thanks
Old 09-23-2004, 06:20 AM
slowgsowner slowgsowner is offline
2g non turbos don't have a MAS they use MAP as for shuddering be more specific.
Old 09-23-2004, 08:45 AM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
Re: Low rpm problem
look up a couple threads, i posted several suggestions for your type of question.
06 Charger SRT-8 black.
the shuddering only happens when the car is under 3000rpm. it happens in any gear with full throttle or any throttle more than that used for slowly accelerating..... that probably didn't make sense, but what im saying is i can baby it up past 3 grand and it runs fine, at speed it runs fine. it feels almost like the fuel is cutting out. i'm not an experienced mechanic, but i've got plenty of time under the car, and it almost seems like its running rich. the injectors are not dirty, so i figured besides from an air leak, it must be electronic. your thoughts?
Old 09-23-2004, 03:27 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Low rpm problem
What plugs are in the car? What are they gapped at?
For Sale 98 Eclipse GS, 5 spd
Old 09-23-2004, 05:35 PM
the plugs are stock, i haven't changed them since i bought the car this summer, the only time i had them out is when i checked the compression, and they didn't look fouled or anything then, that was a few weeks before this started happening.....
Old 09-23-2004, 06:33 PM
ashah000's Avatar
Re: Low rpm problem
I would go and change the plugs.. something like this happen to me and it turned out to be the plugs. My plugs looked just fine also. I would go get NGK BRP5ES, should cost about $7.
Old 09-25-2004, 06:41 PM
Thanks, turns out there was a vacuum hose that was leaking and my plugs were running way lean and were really white. i replaced both, and i plugged up the egr valve, and the problem's gone! thanks for the help
-j
Old 09-26-2004, 08:50 AM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
Re: Low rpm problem
i like the bosch platnum,i know ash does not think it is a good conductor,but he is wrong
Description/Technical Characteristics
Platinum is one of the densest and heaviest metals, highly malleable, soft and ductile. It is extremely resistant to oxidation and to corrosion of high temperatures or chemical elements as well as a very good conductor of electricity and a powerful catalyzing agent
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
