Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-23-2004, 12:03 AM
eliot19 eliot19 is offline
Unhappy Help! 96 Rodeo 3.2 stalls after running for a bit
Hello and thanks in advance for your help.
I have a 96 3.2L 2wd Rodeo with 100K that is developing a problem. On two occasions now the truck has taken to stalling as the rpms drop to idle. This occurs after the engine has warmed up. The engine can be restarted only if the gas is applied and the rpms held above 1500. When it is acting up in this fashion the engine runs sluggish until it hits 2200 rpms or so. After the vehicle has sat long enough for the engine to cool it will run fine. This problem is intermittent and does not happen everytime it is driven. One symptom that may be related, the CEL has come on twice while being driven around. The light went off on both occasions while being driven. The light being on did NOT happen just before the stalling. I recently replaced the PCV and intend to clean the EGR Valve this weekend. I also plan to do the fuel filter and Fuel Pressure Regulator this weekend as well. From what I've read here I don't think its the intake manifold gasket (I hope).
I would sure like to read your thoughts.
Thanks
Old 09-23-2004, 08:33 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Help! 96 Rodeo 3.2 stalls after running for a bit
Yup,this is what I would change next:
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 09-23-2004, 08:55 AM
Ramblin Fever Ramblin Fever is offline
Also check your belts; I have the sister year to yours (i.e. 97) and one day she just stalled out of no-where. Turned out to be one of the three belts were going; another possibility is the idle sensor/regulator??
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 09-24-2004, 06:47 PM
surferfletch surferfletch is offline
I'd have the codes pulled first. You see how varied the suggestions are already...
Now my 2 cents. Could it be a coilpack? Plugs in good shape?
