Old 09-22-2004, 11:56 PM
civicguy167's Avatar
civicguy167 civicguy167 is offline
Send a message via MSN to civicguy167
Gaining More Horsepower
Hey, im gonna be getting my turbo soon and i figure with the turbo and intercooler it should put me at about 203hp, how can i get more horsepower on stock internals (d16y8). I was thinking Throttle Body, Exhaust, and hi-flow catalack converter. What other bolt ons can give me some more horsepower????
Old 09-23-2004, 12:12 AM
95dxcivic's Avatar
95dxcivic 95dxcivic is offline
Re: Gaining More Horsepower
maybe an intake manifold or nitrous intercooler sprayer.
lowered on photoshop(its not that low, its not lowered at all!)
Empty Pockets Racing Member #4
Old 09-23-2004, 12:26 AM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
i would up grade the fuel system, boost controller if the kit doesnt have one, exhaust.
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 09-23-2004, 03:04 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Not even close.
When get'n turbo, you'll need to get a full 2 1/2 exhaust or 3 inch but not necessary. Get a skunk2 manifold , upgrade your fuel injectors to 450cc is good and ditch the FMU and get yourself hondata engine management system. www.hondata.com . You'll see more gains when its tune correctly.
Old 09-23-2004, 04:09 PM
97CivicX's Avatar
97CivicX 97CivicX is offline
Send a message via AIM to 97CivicX
where did you get 203 from? definaetly want to upgrade exhaust to 2.5 or 3. intake would be nice to have(elderbrock) 440 or 450cc injectors with either the hack or honda/uberdata/all the other best choices.
what do you have right now?
D16Y7/D16Y8 mini-me swap
turbo coming this summer
Old 09-23-2004, 07:54 PM
snowman2005's Avatar
snowman2005 snowman2005 is offline
Send a message via AIM to snowman2005
heard the Edelbrock intake manifold was better and easier to install than teh skunk 2 since the skunk2 dont leave much space b/e teh firewall and it.
ive got manuals
92-95 civic 96-98 Civic
clicky here clicky here
WTB:92-95 EX/SI cluster w/tach
FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers
Old 09-27-2004, 08:54 PM
yeah i saw that 203hp on a dyno report somewhere, i think turbod16.com, it had stock internals and a intercooled turbo setup... but anyways how can i acheve that 215hp range on a d16y8? i was thinking...
Turbo Kit set at 9psi
440cc injectors
intercooler
edelbrock intake manifold
edelbrock 65mm throttle body
exhaust
hi flow catalystic converter
what else would be needed to get in that range?
Old 09-27-2004, 09:04 PM
swiftrecon swiftrecon is offline
just a remider. it's catalystic converter.
by the way great choices u had
Old 09-27-2004, 09:06 PM
all fixed
Old 09-27-2004, 09:12 PM
97CivicX's Avatar
catalytic converter
are you going with a kit or custom? if kit, which one?
Old 09-29-2004, 01:59 AM
jameskersten jameskersten is offline
203hp not 202.5hp? jk.
like most people said. upgrade your fuel first, and managemnt, then i would attack the breathing side of things. 3inch exhaust, test pipe(no cat), larger town pipe.
1993 honda civic si -turbo charged b18c1
dynoed: 316whp at 11lbs
Old 09-29-2004, 02:20 AM
BuiltV-TecKiller's Avatar
BuiltV-TecKiller BuiltV-TecKiller is offline
I don't mean to burst your bubble, but don't be suprised if your numbers are lower than 203whp. With stock internals, you're not gonna see 200whp. You might get 174whp give and take 4 or 5 horsepower, which is still not bad. I hope you upgraded the fuel pump. New intake manifold. Bigger exhaust helps. If you have a boost controller, turning it up is at your discresion on stock internals....I've heard good things and bad things about running over 10psi of boost on a D-series so do some research. S-Vafc will give you an extra 15-20whp but you'll DEFINITLY, without question, have to have GET IT TUNED.
No dyno whore, No track slut, just a street bitch...
Old 09-29-2004, 07:50 PM
exman98 exman98 is offline
with any force air induction you will need a high flow exoste and injectors.
running over 10 psi is not good for an engine with stock internals. it would cut its life in half.
people running d16y8's and getting near or over 200whp is amazing and have put a lot of time effort and $ -- over 5g's
Old 09-29-2004, 09:18 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Re: Gaining More Horsepower
werd, we can tell you what things in the kit will be helpful to replace if you are getting a preassembled one.
Empty Pockets Racing Member #1
Old 09-29-2004, 10:25 PM
97CivicX's Avatar
lemme see, you do not need a test pipe you can keep your cat(dont waste money on a high flow one, they do nothing), 200hp is perfectly fine on a stock d16. 10psi with a quality tune will get you there. dont need a fuel pump with afc, dont need a new manifold, and exhaust ideally should be 2.5-3. you wont see a huge power difference between 2.5 to 3 but it will help your turbo spool quicker
