Old 09-22-2004, 09:41 PM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
fuel filter?
every once in a while when i first start my 96 gs is just kinda half dies out and then comes up to idle and runs fine.. its usually when its cold or something and iv only noticed it like 3 or 4 times in the past few months.. so you all think i need to replace a fuel filter or something? i dont know but i dont think it could hurt to replace it. prolly time for plug wires too. plugs should stil be good replaced them 15k ago..
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 09-22-2004, 10:50 PM
macder macder is offline
Send a message via MSN to macder
Re: fuel filter?
does this happen to you on rainy days?
Old 09-22-2004, 10:55 PM
Re: fuel filter?
hmm it hasnt happened when it was raining that i remember.. but its usually in the morning when you got that dew all over stuff.. you think its somethin to do with condensation or something?
AR 15" Baja's
K&N FIPK
Old 09-22-2004, 11:25 PM
Re: fuel filter?
ussually when you ignition wires get old, they let moisture thru which would cause your engine to stutter or stall when cold, try changing you wires if they are old
Old 09-22-2004, 11:31 PM
91_TSI_TALON 91_TSI_TALON is offline
Send a message via AIM to 91_TSI_TALON
Re: fuel filter?
whens the last time u put plug wires on?? cause that haooened to me i changed plugs and wires and its all good now.
Old 09-22-2004, 11:41 PM
Re: fuel filter?
i dont really know how old they are.. they were on it when i bought it... its got 106k so thats the oldest they could be.. i think ill throw a new set on this weekend..
AR 15" Baja's
K&N FIPK
Old 09-23-2004, 02:06 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: fuel filter?
When the car is idling, there is very little fuel flow required. That is not the time a dirty filter would be an issue I cant count how many times poeple change filters for no reason. The danger with a clogging filter is at high fuel flow, or when you are making a lot of power (WOT, under boost, high rpm). They should be replaced regularly anyway, so it doesnt hurt. Just had to point that out
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-23-2004, 05:21 AM
Re: fuel filter?
see now that you point that out it makes damm good sense to me and i feel like a idiota lol.. ok ill prolly replace that too if its not too expensive.. it couldnt hurt.. i think i remember autozone saying 16 or somethin not sure and im too lazy to go check real quick..
AR 15" Baja's
K&N FIPK
