Old 09-22-2004, 09:38 PM
sorner sorner is offline
Angry My squealing engine!
I replaced a timing belt and alt and ac ps belts, now it constantly squeals, not when i start it up, but always. it sounds like the idler pulley squealing or something, but why would it squeal since i replaced the belts?
Old 09-22-2004, 09:39 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: My squealing engine!
sounds like you didnt tighten them enough
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 09-22-2004, 09:43 PM
it doesn't sound like a belt squeal though, it sounds more like a pulley squeal. its constant, it doesn't change pitch if I rev the engine or anything.
Old 09-22-2004, 09:47 PM
spray some wd40 on the pulley bearings. if this fixes the sound you'll probably need a new pulley soon on whichever one was squealing.
-1stGenRocks-
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
lol its a belt, I had the same problem.
UNTIL !! one day in the pouring rain on my way back from school the squeck stopped and I seen my alt., water pump, and powerstearing belt in my rear view mirror. CHANGE IT SOON
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 09-22-2004, 09:49 PM
Re: Re: My squealing engine!
I did the same thing using that belt dressing stuff and it fixed it for like 1 or 2 days then it came back. Mine sounded just like a pully squeck too.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 09-22-2004, 09:51 PM
they are brand new belts though. i tried spraying WD40 in the idler pulley bearing and it didn't change a thing.
Old 09-22-2004, 09:52 PM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
mine sqeaked a lot and my power steering cut in and out.. i figured the power steering pump was half locked up or somethin who knew.. but even tho i thought i had the belt tight enough i gave it a few more turns and it all stoped and everything works great now..
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 09-22-2004, 10:00 PM
Tighten them up more!
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 09-22-2004, 10:03 PM
son of a seahorse! I thought I had it plenty tight. I'll try that tomorrow. I guess if thats it, thats a cheap problem to fix
Old 09-22-2004, 10:27 PM
yea, if i would have tightend the belt like my freind told me to, I wouldnt have had to buy a new belt and watch people look at my car like its a piece of crap when its squeaking.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 09-22-2004, 11:31 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Hey, I'm having the same problem. But when i took it to a machanic today he said it could be the pully. But mine only squeals for like 10 seconds. I told him to tighten my belt, but he said he tightened it as much as he could (which is bullshit). So i basically argued with the guy for like 5 min, until i just gave up. Hes those types of mechanics that think they know everything!
But it still make the squealing noise, how do you know if its tight enough? How tight is too tight?
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 09-23-2004, 01:09 AM
my dad said i should be able to push it down about a half inch with decent pressure.. but im not sure i think hes full of bull sometimes if you get my drift..
AR 15" Baja's
K&N FIPK
Old 09-23-2004, 07:17 AM
i think mine is tighter than that... could it possibly be too tight and causing a pulley to squeak?
