Old 09-22-2004, 09:35 PM
SwiftyR SwiftyR is offline
Send a message via AIM to SwiftyR
58 impala help.....
I just bought the american grafitti 58 impala popped off all the chrome strips and filled it in with body filler the filler is sanded even with the metal but i can still see the texture diffrence is there any way to get it to when i primer it it looks like nothing was ever there
Old 09-22-2004, 10:10 PM
cwmax cwmax is offline
Re: 58 impala help.....
I had the same happen to my Merc. Once you sand and prime again, it will look the same. I did noticed when I sprayed my first coat of color, I could still see the places where I used Bondo. After the second coat I couldn’t see them anymore. I'm thinking the primer is not sealing.
What primer did you use? I used WalMart primer, I don’t think it’s too good. I will try Duplicolor Primer-Sealer on the next, it should help keep the Bondo from sucking up the paint.
Could also be we should be using some other filler besides Bondo. This is my first experience using Bondo on such a small scale. There are finer fillers for plastic models. Meaning the filler is less porous. Have to experiment I guess, Unless someone else knows for sure what fillers and primers should be used.
Old 09-23-2004, 12:00 PM
I used the wal mart primer also.....maybe ill try finer sand paper
Old 09-23-2004, 12:46 PM
Gafoto's Avatar
Gafoto Gafoto is offline
Send a message via AIM to Gafoto Send a message via MSN to Gafoto
Re: ...
You aren't using really rough sandpaper are you? Body filler is probably softer than solid metal so it's likely that it the sand paper will damage it more.
Old 09-23-2004, 04:27 PM
Tommycool666 Tommycool666 is offline
you gotta get the high build formula primer by duplicolor and then get the primer sealer by duplicolor and im pretty sure it will be fine
