Old 02-12-2002, 05:25 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
Angry "Kerplunk" sound!
Hello, I have a question, and I dont know if anyone will know what I am talking about, but I am going to try anyway... After I got home from school (a 35 min drive) I turned off my Accord (I installed an APC "Ram" instake just 3 weeks ago) and after the car sat for a couple minites, I heard this "Kerplunk" sound come from the Air intake (at least that is where is sounded like it was comming from) It made a sound that sounded like a brick was being dropped into water. I later went to work and when got back, turned off the car to see if it happend again. This time I heard nothing. Does anyone know what this is? Do I have anyhting to worry about? Am I going Insane?
Thanks a lot for any help!
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 02-12-2002, 08:31 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
Take two asprin and call us if it happens again.
Old 02-13-2002, 01:12 AM
MARKUSIUDIUS MARKUSIUDIUS is offline
Sounds like
What is the year of the Accord. Id say it has nothing to do with the air intake. Put the original back on and see if it still does this. If it does than listen, are you sure it the intake not the clutch or cam cover section?
And if it is the intake Id say its those gremlins playing tricks again and if it is. Make sure you dont fill up petrol after midnight and dont get the car wet.:flash:
1994 2.2lt Jap import Vtec, Blown with a 1GGZE charger 300Hp or 220+kw
Malpassi Reg, 500 injector, Unichip piggyback management system, Top gun leads, Map controller, Vtec controller, Custom FM Cooler, Custom fast flow exhaust and weight reduced (2640pds)
Old 02-17-2002, 09:27 PM
90civichbsi 90civichbsi is offline
Send a message via AIM to 90civichbsi
i actually think i know what you are talking about. MY car has made that sound, but it does it when it kills itself. i have a pretty bad idle, and its made the sound a couple of times mine sounded like it was comming from the crankcase i dont know what the heck it is.
My 1990 Honda Civic Si
i/h/e
gude head
gude cam
gude ecu
2" lowering springs, camber kit etc.
wings west front bumper
powder coated GSR rims
Old 02-18-2002, 09:30 PM
praxis praxis is offline
Yeah, mine does it if I turn the key off and back to the on position immediately after.
I have never figured it out, but it seems as though (in the that split second) the engine turns off (when the key is switched) and wants to pick up where it left off (when switched back to the 'on' position)...but nothing is there.
I just don't switch the key off and back on anymore.
PraxisPerformanceAutoworks LLC High performance autoparts & accessories.
________________________
sales and specials...Konig wheels, Accmat carpets, Thermal exhaust, DragunFire mufflers
_____________________________
PraxisForums...informative information
PraxisRacing is sponsoring. click for more info.
see PureHonda in its original colors-->
Old 02-18-2002, 11:40 PM
-=Evol90Accord=- -=Evol90Accord=- is offline
mine does that all the time!! i turn it off, and it just goes kerplunk and thats it. never figured out what it was. I though maybe it was my transmission in going into park.... somebody told me the engine releases something when it does that. Personally i thought he was on crack cuz it sounds like the motor.
The real problem is having your head under the hood while you turn off the engine
I guess you could ask someone to do it for you, but it never makes that sound unless im alone.........................
its a lowered family sedan... how fast could it possibly go??
