Old 09-22-2004, 08:37 PM
89k5 89k5 is offline
350TBI timing
Hopefully somebody remembers, cause I don't, the proper wire to disconnect to check the base timing on the fuel injected engines. I remember that it is usually brown with a black tracer. I haven't crawled in there yet to check for it, anybody know?
Old 09-22-2004, 10:28 PM
slammed s10 87 slammed s10 87 is offline
Re: 350TBI timing
ITS A BROWNISH WIRE UNDER THE GLOVEBOX...ITS THE ONLY ONE WITH A CONNECTOR ON IT-LEE
Old 09-22-2004, 10:31 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: 350TBI timing
What he said!^^^^
Old 09-22-2004, 11:22 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
full size blazer/tahoe or the s10 blahzer? s10s are almost always under the blower duct tucked under the carpet, the bigger stuff differs year to year and is sometimes under the hood by the power distribution center on the passenger firewall
Old 09-23-2004, 02:19 PM
Re: 350TBI timing
Thanks for the help, I will go check shortly and let you know how it turns out.
Old 09-24-2004, 11:28 AM
Re: 350TBI timing
O.K., on my fullsize 89 blazer, with 350TBI, 700R4, the brown wire with black tracer is under the hood. The wire is on the driver side, by the firewall, and there is about six inches of wire with a connector sticking out of the wiring loom that comes thru the firewall. I disconnected it and checked my timing, it was about 20 degrees advanced!!! I changed it to the factory stated 0 degrees, tightened the clamp, rechecked it, then shut it down. Disconnecting the wire made the check engine light come on while the engine was running, but after turning off the engine, reconnecting it, and starting it back up all was good. I lost the stumble at about 2800 RPM, but it has a slight cough leaving the stop light, sometimes. Thanks for the help guys.
Old 09-24-2004, 12:10 PM
BlazerLT's Avatar
AF -Advisor
Re: 350TBI timing
Yea, you were running really lean there.
The timing wire is for the spark advance and you just reset your timing to zero so it could properly advance the timing.
This would have led to your overheating like you have talked about in the other thread.
