Old 09-22-2004, 05:39 PM
86_SR5's Avatar
86_SR5 86_SR5 is offline
Question Cleaning Off Compound/Waxed Surfaces...
Hey everyone. I have a car that I painted almost 8 months ago and it has been compounded and waxed 50 times over. However, I found some details that I'd like to brush a light gunmetal color over. I rinsed the body of its dust, and dried it with a soft towel. I applied the usual thin coats of paint to build up a smooth life-like dry gunmetal surface. Upon inspection this morning, I found that there are places where it looks like someone drug a thick piece of wire through my gun metal paint. So I figured it had to be because of the compound and wax that were still on the body.
Today I gave the entire body one hell of a scrub with mild hand soap and a new soft bristle toothbrush. It removed some of the gun metal paint and may have cleaned the surface well. I would just like to know, what would be the best soap to use so I don't damage the already painted body? Thanks for your help.
RIP Indian Larry RIP
April 28th, 1949 - August 30th 2004
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 09-22-2004, 05:54 PM
freakray freakray is offline
AF Modelrater
Re: Cleaning Off Compound/Waxed Surfaces...
What kind of paint is the body painted with?
AF User Guidelines
Old 09-22-2004, 06:44 PM
86_SR5's Avatar
Tamiya lacquer mica blue, testors true blue pearl enamel on top fade line visible into the mica blue lacquer.
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 09-22-2004, 07:40 PM
AF Modelrater
You should be able to safely use rubbing alcohol to remove any wax you're put on the body then.
AF User Guidelines
Old 09-22-2004, 09:49 PM
swollen swollen is offline
Dish soap will strip wax, that's why you shouldn't wash your car with it
HI! I'm your friendly nieghbourhood Mike.
Just so you know, giant pictures in your signiture make the baby Jesus cry
VW Vortex.com
VW Drivers of Vancouver
Mine = 1990 VW Jetta Xflow ...all go, no show.
Hers = 2000 Pontiac Sunfire... I know, i know
Old 09-23-2004, 06:30 AM
AF Modelrater
The problem with dish soap is they contain smalll amounts of silicone which can also prevent paint from adhering.
AF User Guidelines
Old 09-23-2004, 02:52 PM
cogitator56 cogitator56 is offline
Send a message via AIM to cogitator56
Re: Re: Cleaning Off Compound/Waxed Surfaces...
Are you sure this is safe for the paint? In this earlier thread it was mentioned that 91% alcohol would strip tamiya lacquer.
http://www.automotiveforums.com/vbul...d.php?t=275770
Old 09-23-2004, 02:54 PM
AF Modelrater
So use 70%.
I didn't say to soak the body in it, just lightly rub to remove the wax, I've done it and it works, have you?
AF User Guidelines
