Old 09-22-2004, 04:51 PM
coolguycooz coolguycooz is offline
Rich or Lean???
Ok how do you figure out if you are running rich or lean and also i have another quick question . When i start up my car it smells like gas for a little bit for like 10 seconds then it stops but when its stopped or idling it dosent smell like gas only for the first 10 seconds after its been standing over night is something leaking? i dont see any gas on the ground and i checked the fuel lines nothing could it actually be because i have a messed up coil pack and wires right now? or my fuel injectors leaking or the fuel rail?
Old 09-22-2004, 08:39 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Rich or Lean???
My guess would be...until those components "warm"up it could cause some unburnt fuel....
Is the smell from exhaust only?
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 09-23-2004, 02:17 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Rich or Lean???
The car will run rich on cold starts, its the same as the choke function on carbuerated cars. If its a real leak, you should find it asap. Look under the hood at the rail/injectors and all fittings right after you start the car, just in case.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
