Old 09-22-2004, 04:00 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
swapping motors
my friend has a 1990 civic 4 spd STD HB,
& wants to know if he can take a honda accord motor 2.0 & put it in the 90 civic std,also a 5 spd accord tranny,
if it will,what would all have to be replaced on the civic from the accord?
if you have any suggestions that would help him out let us know,
In the process of B00stin my D
Old 09-23-2004, 02:21 PM
soooo.....nobody knows....
Old 09-23-2004, 02:32 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: swapping motors
Its kinda like put'n the h22 in. I believe you will need the aftermarket h22 swap mounts for the 4th gen civics. I dont know anyone with that type of set up. I would rather put an h22 if you're goin through all that trouble. STD has dpfi which you need to convert to MPFI, you will also need dx/si hubs. Tell him to get another swap.
Old 09-23-2004, 10:04 PM
DJHyperXK2004's Avatar
DJHyperXK2004 DJHyperXK2004 is offline
Send a message via AIM to DJHyperXK2004
Re: Re: swapping motors
Originally Posted by mellowboy
you will also need dx/si hubs..
Whats a "hub"??
1990 DX Hatch
17" 5Zigen Copse Rims
CIA, 4-2-1 Header
H/F Cat, 5Zigen Exhaust
Circle Earth kit
B swap in the spring???
PIX OF MY CAR
Old 09-23-2004, 10:25 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
you know the part with the studs that the brake rotor sits on..has splines in it for the axlem cause you cant use the original STD axles.
