Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-22-2004, 01:38 PM
nguyentung18 nguyentung18 is offline
Unhappy burning gas
I just bought a 2000 civic hatchback CX, it was runnung fine about 40 miles per gallon, but then after I either pump 92 gas into my car, and i think i broke the metal piece hanging where you pump your gas into and it probably drop into the gas tank and i dont mean the gas cap it started to burn gas alot, im getting about 20 miles per gallon now. I also tuned up my car to, by changing the oil, i might have put too much oil, i might have tighten the spark plugs and the oil filter too much. Is there any advice for me. I also would like to know if i could get into my gas tank.
Old 09-22-2004, 02:29 PM
383PhoenixAm's Avatar
383PhoenixAm 383PhoenixAm is offline
Send a message via AIM to 383PhoenixAm Send a message via MSN to 383PhoenixAm
Re: burning gas
I'm not sure losing that blockoff plate will cause bad gas mileage. I don't see any reason for that. I would check for leaky injectors first of all. Also make sure that you gapped the spark plugs properly. It can come back to get you later.
Old 09-22-2004, 02:58 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
the only thing that might do is block your fuel pump from getting fuel but the pickup is really big so i dont think its that.
Team Lonely Drivers
Old 09-22-2004, 07:16 PM
civichatch982 civichatch982 is offline
yea I'm having a similar problem with mine. I have a 96 civic hatch. I only get prob 21 mile per gallon on that thing but I always figured it was the CAI + headers + tanabe exhaust. I know the headers make my engine light come on for the 02 sensor .. but I never could figure out why my car was running so rich.
Old 09-22-2004, 08:09 PM
Re: burning gas
The O2 sensor is one of the things that tells the computer to adjust pulse width on the injectors. If the O2 happens to see a lean condition in the exhaust it will make the comp feed more fuel.
Unless you mean that it runs rich to begin with. Then its some other sensor.
Old 09-23-2004, 01:23 PM
swiftrecon swiftrecon is offline
Re: burning gas
definitely a fuel system problem..if lucky..then probably just a bad tuneup
Old 09-23-2004, 02:31 PM
Re: burning gas
yea it was so bad at oen point i had to replace an 02 sensor. Deffinantly not cool. I think my ecu may be chipped too... butI'm not sure. I've tried ot lean it out. I put a high flow cat on it to see if the secondary 02 would fix it a little bit and I've tried to lower the fuel presure a bit cause I have an adjustible fuel presure regulator. but I only got like 1 ro 2 extra miles per gallon with it. Haha I went from getting about 198 miles ona tank to 220.. ish.
