Old 09-22-2004, 01:20 PM
just4phun just4phun is offline
Unhappy squeaky driveshaft???
I think this is the problem but I'm not too sure. I get a squeaking noise that sounds like it’s from the driveshaft. The squeak pitch increases as I accelerate. I went underneath anD moved the driveshaft back and forth and it squeaked a bit. Anyone else experience this problem? I did not see any grease fittings to grease which my fix the problem.
Any ideas would be helpful. I will try in 4Hi and 4Lo tonight to see if anything changes.
Cheers!
Old 09-22-2004, 01:38 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: squeaky driveshaft???
Any vibration, funny (airplane type) noise, or clunking sounds when reversing gears?
Old 09-22-2004, 04:23 PM
broughy84's Avatar
broughy84 broughy84 is offline
you need new u joints
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 09-22-2004, 06:18 PM
Mikado14 Mikado14 is offline
I second that!
Old 09-22-2004, 10:40 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
U-joints OR you just need to get your U-joints greased.
Old 09-22-2004, 10:46 PM
broughy84's Avatar
newer u joints do not have grease zerts, so you can't really grease them without taking them out and removing the caps. And if you do that, you might as well put new ones in.
Matthew Brough
Old 09-22-2004, 10:53 PM
slammed s10 87 slammed s10 87 is offline
Re: Re: squeaky driveshaft???
if you moved the u joint back and form thats usually a good indication that you need u joints also check the tranny mount. when mine was bad i had a squeak when i drove it that i though was the u joints
Old 09-22-2004, 10:57 PM
BlazerLT's Avatar
AF -Advisor
You are wrong on Blazers.
Stock have no grease fitting and the aftermarket ones do.
trust me, I own both.
The new one had a grease fitting.
Old 09-23-2004, 03:25 AM
roadieken roadieken is offline
Re: Re: Re: squeaky driveshaft???
Yep. What he said! Be sure you put the new ones in with the zert facing the right way. I put mine in wrong the first time and couldnt get to the zert.
Old 09-23-2004, 08:14 AM
Thanks for all the input. I will check the U joints. Too bad the stocks have no grease fittings.
Cheers!
Old 09-23-2004, 09:02 PM
wilfie27 wilfie27 is offline
To get the stock ones off you have to heat the yoke ends. There is a plastic ring that holds the U-joint caps in place. It will seperate easier if it melted a bit. I didn't have a torch and since my driveshaft was on the ground I let it set in the sun for about an hour and it softened up enough.
