Old 09-22-2004, 01:16 PM
gdawg415 gdawg415 is offline
Unhappy Help my door wont shut
I have a1991 Chevy S-10 Blazer and my passenger door won't close. The door latch seems to be stuck so it will not allow my door to close. Does anyone know how I go about fixing or replacing this. I tried prying at it with a screwdriver with no luck. Any suggestions would be appreciated.
Old 09-22-2004, 06:11 PM
Trail Blazin96 Trail Blazin96 is offline
Send a message via Yahoo to Trail Blazin96
Re: Help my door wont shut
I had a car once that the latch would get stuck in the shut position, i think if you open the door from the inside it might shut then!
Old 09-22-2004, 10:42 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Spray it down with WD40 make sure you free it up.
can you see where it is catching?
Is it rusty?
Old 09-22-2004, 10:47 PM
slammed s10 87 slammed s10 87 is offline
Re: Re: Help my door wont shut
Is it rusty?
wack the crap out of it with a sledge!
Old 09-22-2004, 11:00 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Help my door wont shut
Can you grow up a bit?
Old 09-27-2004, 07:36 PM
It would be nice to hear if any of the suguestions except for one worked!
Old 09-28-2004, 02:35 PM
gmsteve455 gmsteve455 is offline
As Trail Blazin suggests, the latch is probably stuck in the shut position - I've seen this on a suburban before. For some reason when the door was opened, the latch didn't set to the open position. Look at the latch on the side of the door. Put your finger in the slot and push the latch to the open position - you may also need to hold the door handle up as you do this so that it releases. WD-40 and some white lithium grease might help the situation if it's rusty. Good luck.
Old 09-28-2004, 08:43 PM
At least some people can see that I do know what I am talking about
Old 10-04-2004, 07:32 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
i had this happen on the drivers side on the 91 s10blazer take a scissors or flat headed screw driver and go behind the latch and pry up and out and spray it so heavy u can smell the wd40 for days that seemed to solve the problem
