Old 09-22-2004, 12:17 PM
SeXy_MaMaRST SeXy_MaMaRST is offline
Exclamation Eclipse RST Problem..NEED HELP!
Hey everyone. I am new to this site, but while looking at the search, I can tell alot of you have some good knowledge on the eclipse RST. I have recently built my RS with Forged pistons and rods because I had turboed it and blew out the ringlands on two pistons. So obviously, I was running too much boost. Everything was rebuilt, got the head ported and polished. Now that everything is back together, I have a problem that I can't figure out.
When first put back together, it ran perfect. Now, if I shift into third gear and get on it, my blow off valve goes off and the car starts to feel like I shifted, but haven't. It is kinda like the feeling of letting off the gas even though I am not. What is it? How can I fix it? Any suggestions?
Old 09-22-2004, 01:39 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Eclipse RST Problem..NEED HELP!
So it sounds like a problem with your blow off valve or the vacuum hose thats supposed to go to the manifold.
Old 09-22-2004, 02:12 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
throttle cable adjustment???
and check the hoses are good and in the right places...
Old 09-22-2004, 02:33 PM
Re: Re: Eclipse RST Problem..NEED HELP!
What would be wrong with the blow off valve? What would I need to look for to see if something is wrong with it?
Old 09-22-2004, 02:36 PM
JoeWagon's Avatar
Banned
Could be leaking, or could be hooked up incorrectly as to cause it to open prematurely. What kind do you have?
Old 09-22-2004, 02:39 PM
I have JDM Blitz Super Sound.
Old 09-22-2004, 05:12 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
what are you using for a fuel controller and injectors/pump? and how much boost are you running? sounds to me like your maxing out your injectors/pump... doesnt feel anything like fuel cut, it feels as if you let off the gas or the motor died!
Old 09-22-2004, 05:24 PM
I don't have a fuel controller right now but I do have my air/fuel ratio gauge set up. It is always runnig a little rich, but not much. I have 350cc injectors and BBK fuel pump (not sure on the size right now, at work can't look )
It isn't fuel cut at all because I had that happen really bad before I got the pump.
Old 09-22-2004, 05:42 PM
EclipseRST's Avatar
Banned
i know its not fuel cut... but you need a fuel controller, your A/F gauge is worthless in my opinion, what are you using to compensate for the added air that enters the motor? and how much boost are you running?
Old 09-22-2004, 05:47 PM
Right now since the car started acting up, I turned it down to 8 psi. Before when I had no problems with it I was running 15-20 psi.
Old 09-22-2004, 05:48 PM
What fuel controller would you suggest me using?
Old 09-22-2004, 06:13 PM
JoeWagon's Avatar
Banned
S-afc2
Old 09-22-2004, 06:35 PM
I bought a S-AFC2 and it had no instructions for an RS.
Old 09-22-2004, 06:53 PM
EclipseRST's Avatar
Banned
what are you using to compensate the MAP sensor so the computer doesnt see so much pressure in the manifold?
also, the S-AFC2 will work on any car!
EDIT: i dont under stand how you ran 15psi with that set up... no fuel controller will put your 350 injectors to stock level cause the computer doesnt see them as bigger so they will only flow the stock 240cc level.
Old 09-23-2004, 10:16 AM
I don't have anything for the MAP sensor. What do I need? And if the S-AFC 2 work on every car, what wires do I need to hook up to make it work?
The car ran a solid 15 - 20 psi, no problem until recently.
