Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 09-22-2004, 11:55 AM
ibejumpin ibejumpin is offline
Unhappy engine surging
Hi, the engine on my 2002 Accent has started "surging" when driving on the freeway. It seems to happen after the engine is warm and when I release my foot off the gas. I also noticed that the rpms surge when I'm downshifting. What causes this and how can I fix it?
Old 09-22-2004, 06:01 PM
SoftFiZ SoftFiZ is offline
Re: engine surging
Hello there, I also have an '02 Accent and experienced very much the same problem.
I could be sitting at a light and all of a sudden the car would just want to go. Forcing me to hold the brake tight.
Also, when driving, it would clunk as it was still applying gas during shifts.
It was actually pretty scary.
Went in and had them take a look, it turned out to be some gas sensor, they had some stupid name for it. Anyhow, it was easy for them to find and they changed it under warrenty.
Took about an hour to fix.
Just take your car in and tell them the problem you're having, I'll bet it's quite commen.
The Accent is a good car, but it has it's quality quirks.
Good luck!
Old 09-22-2004, 06:03 PM
Re: engine surging
Thanks for the advice.
Old 09-22-2004, 07:30 PM
andrew348 andrew348 is offline
Re: engine surging
Sounds like a tps sensor problem it is covered 5years 60 k . tps = Throttle position sensor .
I replace a lot of these on hyundai accents
Old 10-06-2004, 01:48 PM
barbscar barbscar is offline
Re: engine surging
I have an 2001 accent and since july I have had the throttle position sensor ,the crankshaft position sensor , the control relay ,and the engine control module replaced in it. right now it is at the dealers getting a new converter put in it. car had 44,000 miles on it. I have really had it with this car its in the shop more then its on the road. i affraid of what is going to happen to it next.
