Old 09-22-2004, 11:13 AM
bigdaddyviking67 bigdaddyviking67 is offline
Front Wheel Drive Accuator
My 4 wheel drive accuator is bad, where is it located? My Haynes manual doesn't show it?
Old 09-23-2004, 12:06 AM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
well you could have 2.....
all models have on on the front axle that slides a collet to join the axle halfs together.
but if you have 'push button' 4x4 shifting, you also have one on the xfer case that engages the 4wd planetary
Old 09-23-2004, 09:28 AM
Actuator
Thanks, I don't have a push button, and I figured it was on the front axel, just wanted to make sure before going on a wild goose chase.
Old 09-23-2004, 10:01 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Re: Front Wheel Drive Accuator
The actuator GMs part number 26013495 is located in the front differential. There is also an updated electric one available from gm but the harness has to be changed to use it.
Old 10-20-2004, 05:20 AM
mbusansky mbusansky is offline
I replaced my OEM CAD with one of those Posi-Lok kits. Seems to work OK.
Old 08-04-2010, 10:59 AM
DonEd DonEd is offline
I have a 2005 and was having similar issues. In key position one all lights light. At first I could turn on and off several times and push the 4H and eventually it would engage. Now nothing except all the lights still light up upon starting. How can I tell what my issue is.?
