Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 09-22-2004, 09:33 AM
william e smith william e smith is offline
Question service traction light on
my service traction control comes and the abs light comes on also trac off comes on when you turn the car to the right.
Old 09-22-2004, 01:11 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: service traction light on
you have either a bad hub bearing or a broken wire from the frame to the abs sensor wire at the wheel
Old 12-01-2006, 10:48 AM
mawyatt1972 mawyatt1972 is offline
Service Traction Light On,the Trac Off Light Too,the Abs And Brake Light Flashed A Couple Times Help
Old 12-02-2006, 06:37 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Welcome to AF.
A couple pointers here to help you out.
Year make and model of your vehicle will help get you information faster.
Thank you for doing a search and finding this dead thread from 2 years ago.
May I suggest that in cases like this you start a new thread.
Here is some information to get you started.
SERVICE TRACTION SYSTEM
The IPC illuminates the SERVICE TRACTION SYSTEM indicator in the message center when the electronic brake control module (EBCM) detects a malfunction in the traction control system. The IPC receives a class 2 message from the EBCM requesting illumination. The SERVICE TRACTION SYSTEM indicator illuminates for 60 seconds when the condition is present. The IPC sends a class 2 message to the radio in order to activate an audible warning.
TRAC OFF
The IPC illuminates the TRAC OFF indicator when the following occurs:
The electronic brake control module (EBCM) inhibits the traction control system due to a malfunction in the traction control system. The IPC receives a class 2 message from the EBCM requesting illumination.
The body control module (BCM) detects that the traction control switch has been pressed (signal circuit is low). The BCM sends a class 2 message to the EBCM in order to disable traction control. The IPC receives a class 2 message from the EBCM requesting illumination. The BCM sends a class 2 message to the radio in order to activate an audible warning.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
