Old 09-22-2004, 01:09 AM
anonymous_1 anonymous_1 is offline
Send a message via AIM to anonymous_1
d16a6 swap help
i had a d15b1 dual point. i just swapped a si d16a6 non v-tech, it runs but it dies while i go driving i dont know whats wrong with it.. i have high compression pistons in it and dont know whats wrong with it. i kept it dual point cuz i couldnt find the wiring harness. any help on this problem would be great. i dont know if its my timing, or the cap/rotor spark plugs/wires...i just dont know....
Old 09-22-2004, 08:49 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: d16a6 swap help
Hi noob, welcome.
Look into the main relay or the dizzy (maybe the igniter).
I had the same problem and a new (to me) dizzy seemed to have solved the problem. GL
Old 09-22-2004, 11:41 AM
88ReX 88ReX is offline
are you using the a6 distributor or ecu? Bc if you are it's not ging to work. Just do the mpfi wiring yourself man its pretty easy if you have the time.
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
Old 09-22-2004, 11:42 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: d16a6 swap help
did you use the the d16a6 ecu (pm6)? did you use the d16a6 dizzy with the d15 ecu? either one of those could be the problem. it needs to be ecu, dizzy, and intake mani from the same set-up.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-22-2004, 12:54 PM
Re: Re: d16a6 swap help
so are you saying it wont work right if it just stays dual point that i need the mpfi not dual point
Old 09-22-2004, 01:15 PM
amy@af's Avatar
Re: Re: Re: d16a6 swap help
no, i'm not saying that. the engine can work DFPI or MPFI. if that were the case nobody would be able to convert their d15 to MPFI.
i'm saying you have to either use MPFI or DPFI parts....one or the other. you can't mix ecu, dizzy, and intake mani.
make sense?
hit me up on AIM (LadyNRedSi) if you are still online
