Old 09-22-2004, 12:16 AM
1lo94 1lo94 is offline
Question o2 Sensor in Cat Converter Question
I have read somewhere recently that if you remove the sensor from the cat and rap it in tin foil it will do just fine. I'm ready to install a high-flow CAT and it doesn't have a place for the sensor. Am I right about the tin foil thing? What should I do exactly? Thanks
~JetK.
1994 Mitsubishi Eclipse GS (in the process of turboing)
vote BUSH 2004
Old 09-22-2004, 03:41 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: o2 Sensor in Cat Converter Question
Yes, leaving it to open air will usually make the ECU think the cat is present and functioning. The foil trick is a safety precaution, the sensor is heated and gets a bit hot. I recomend wrapping it in foil, but leaving it OUTSIDE the car, ziptied to something underneath. Some poeple put it in the car, under the seat. Sounds awefully risky to me
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
