Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani > General Topics
Old 09-21-2004, 09:49 PM
tibby01 tibby01 is offline
One available firewall passageway
for the RD series tibs. 97-01.
cut a little hole in that plug right behind the Throttle Body. wrap whatever you need to fish through with a "unravelled" coat hangar. then just push it through. it would be a good idea to take off the plastic panel that covers the bottom of the steering column and contains the dimmer switch, so you can grab the wire.
two screws at the bottom of it, pop out that little tab at the top right to expose another screw. to get to the other one, i get some needle nose pliers, grip the dial of the dimmer switch, then gently pull on it untill it pops out.
use www.hmaservice.com/webtech for everything!!!!! just spend some time looking through it, the thing is great.
heres some quick pics of the spot i snapped.
other people have said there is a spot down by the passenger cabin fuse box that is much bigger too. check this...
http://www.hyundaiaftermarket.com/cg...=000686#000000
Old 12-18-2004, 09:08 AM
twospirits twospirits is offline
Ex-Janitor of AF
Nice write up. Thanks. It will surely come in handy for the members to follow through.
BTW, one question. For those that have an automatic, would you it be safe to say that one can also go through the firewall where the clutch pedal would have been? Please advise.
Thanks, good job.
TS out
The more the members are involved in the process of development, the better we will be as a community of Automobile enthusiasts. Have a suggestion to make the community better, let us know.
Remember, the "No" is always there, you are just looking for the "Yes"
Members please read: Guidelines
Old 12-18-2004, 04:15 PM
there is a plate there on the automatics, tha can be removed via a couple bolts i think. i guess you could use that.
that spot by the fender seems to be the popular alternative for bigger wires though.
