Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-21-2004, 09:37 PM
lightin rod lightin rod is offline
Send a message via MSN to lightin rod
window regulator
ok i asked about this once but it didnt work. i have a 94 thunderbird lx and the power window on the drivers side and it cathchs somethimes and i can grab it and pull it up and down i talked to somebody that used to work for ford and they said either the regulator is bad or the cable broke. I looked around and found a ford dealer and i think its about 200 to have them fix it. so does anybody have an idea what is bad. and if so how do i fix it thanks in advance
Old 09-22-2004, 12:24 AM
Mike75 Mike75 is offline
Re: window regulator
That dude left out the most probable option. There is a little case with three little plastic egg-looking bearings in it. One of those is probably broken. Happens all the time in many types of cars. I replaced the broken one in my 86 Bird with a 1/4" nut.
I have a similar situation in my bird right now, but this one requires a good karate chop to the door panel while holding the window up/down button.
Old 09-23-2004, 01:13 PM
Bird_Of_Prey Bird_Of_Prey is offline
Here's an odd one, its been about 6 months since ive had the gears replaced in the automatic window system, these gears frequently go bad causing the window not to move. But, after 6 months, my passenger window moves DRAMATICALLY slower than the drivers side..im stumped, any suggestions?
Old 09-24-2004, 05:11 PM
ok how do u get to these bearings?
Old 09-24-2004, 05:35 PM
Scott Long Scott Long is offline
Go to autozone and get a new window lift motor. Take off your door panel, unscrew and unplug the speaker. Stick your hand in through the speaker hole, grab the motor. Take out the three 8mm bolts on the front of the door, and pull the motor out through the speaker hole, unplug it, replace, bolt it in, plug it in, put on door panel, now you have a working window. Its a 5 minute job.
Old 09-28-2004, 08:47 PM
the motor still runs so why replace it?
Old 09-29-2004, 04:03 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Go here: www.windowmotorstexas.com. They should have the gears to fix your motor. And what cable is the mechanic talking about? I've never heard of such an animal.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 09-30-2004, 04:19 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Re: Re: window regulator
I've had my Bird for 3 years, and recently I've noticed the same problem. The Passenger side window is slower, and makes a slight murrrrrrr sound when you lower it slightly. *bump*
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 10-03-2004, 03:31 PM
Just cuz the motor runs doesn't mean it isn't weak and worn out. Both times I've changed mine they still ran, just slow, or not enough strenth to move the window very far, but when you took them out of the door they run fine.
Old 10-05-2004, 02:03 AM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
speaking of windows, sometimes mine get "stuck" right at the very top when I am trying to close them. They still move up and down but its like they are getting blocked right at the top, so I have to roll em up and down until the window decides to shut all the way. Not a big problem and not very frequent, but I was wondering if anyone has had the same problem and knows how to fix it.
Old 10-07-2004, 04:38 PM
Are you driving on the highway or is this happening while sitting still or at lower city speeds?
Old 10-07-2004, 06:54 PM
i drive both for the most part because the new city cop / dot officer is a a**hole so i dive the low speeds when he is a round and highway speeds because i live in a small town so if i want anything i have to drive a half hour to get it. so both bascally
Old 10-08-2004, 03:50 PM
Our birds have an inherent problem when driving at highway speeds and having a cross wind. The air pressure will suck one window out a bit and cause it not to close all of the way. I have had to roll down the opposite window to relieve that pressure to get the window up and then close the opposite window. This is why I ask.
