Old 09-21-2004, 09:13 PM
kr10298 kr10298 is offline
96 Blazer S10 Code P0101 Maf Or Vaf
My Blazer s10 96 has no acceleration. After driving it excessively today I got the ECM to cough up a code. It was "P0101 MAF OR VAF CKT RANGE/ PERFORMANCE". I am not sure what VAF is. But I looked at the Air meter made sure there was no visual debris and that the wires/plug was well connected. Before replacing the MAF meter, I was wondering if this code could be something else? Any comments are apreciated.
thank you.
Old 09-21-2004, 10:47 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 96 Blazer S10 Code P0101 Maf Or Vaf
Have you ever done a tuneup? When have you done it?
What have you done maintenance wise?
Do you have an after market intake on your truck?
Have you Descreened the MAF?
Old 09-23-2004, 01:09 PM
Thanks for the reply,
I have not done a tune up in over a year.
The truck is all stock. No K&N filter, no descreening of the MAF.
I ran the car without the filter and it ran good. So I replaced the air filter hoping that was the problem. And it did help for a day. But it started to do it again. When it does it, there is no power, and when I press the gas pedal it feels like it is just sucking air. It does not always pop up the "check engine light". I have to push it real hard for that to pop up. I disconnected the MAF plug wire and then re-connected it and it appears to have gone away for now.
I am not too sure what to do when sometimes it works and sometimes not.
thanks,
Old 09-23-2004, 01:30 PM
scholzee scholzee is offline
I have had a similar problem with mine, when it does it try running it with the gas cap loose see if it helps. The gas cap has a vent and if it does not vent properly a vacuum builds up in the tank as fuel is removed and the fuel pump can not pump at the proper pressure.
Old 09-23-2004, 01:46 PM
BlazerLT's Avatar
AF -Advisor
thanks,
What did the tuneup contain?
Old 09-23-2004, 09:42 PM
The tune up was only change in
Plugs,fuel filter,cap,rotor and air filter.
I just wish it would break down for good. I think it is easier to troubleshoot that way. If sometimes it works and sometimes not...this really confuses me.
Old 09-23-2004, 10:04 PM
BlazerLT's Avatar
AF -Advisor
sound like your MAF sensor has gone bad.
Time to change it.
Old 09-24-2004, 11:07 AM
Can you specify where is the sensor. Is it right after the whole meter assembly? or do you mean replace the whole meter.
Thank you
Old 09-24-2004, 11:59 AM
BlazerLT's Avatar
AF -Advisor
It is half way between where the air intak connects to the top of the engine and the airfilter.
It will have a connector attached to it.
Old 09-25-2004, 11:35 AM
69CamaroRSSSLover 69CamaroRSSSLover is offline
MAF = Mass Air Flow
VAF = Volume Air Flow
Generally this means the sensor is bad - replace it and this should correct the problem - if not post and I will locate testing procedure for wiring diagnosis
This is a UK website but DTC definitions are extremely easy to obtain and read:
http://www.gendan.co.uk/diagnostic/dtcs.php
Old 09-25-2004, 09:29 PM
BlazerLT's Avatar
AF -Advisor
The MAF has to be replaced.
