| Off-Topic Talk about anything other than cars. |
I have a 96 spyder GS that started leaking water into the car recently. It's mainly in the rear passanger area and seems to pool up under the rear passenger floor mat. Ive done some research and this seems to be a fairly common problem with Spyders, so my question is does anyone have any ideas on how to stop the leaking without getting raped from a dealer whose probably not going to be able to fix it right anyway? I've heard about using silicone or scotchguard. Has anyone tried these and had success?
Re: leaking convertible top
the seals are out. Happened to my 98 spyder. IS happening to my 97 spyder. the seals right above the window collapsel try to manually pry them into shape... you just have to see where the seals bend in so that they let water thru, and then try to patch it up, or stuff that area with some other material...
I got my right hand and my left hand, I can smack you with both. -De Niro ![]() 1996 Mitsubishi Eclipes GS Syder 2.4liter engine - Stock
JUST USE SCOTCHGUARD!!! I DID!! AND IT WORKS!!!
Read the other post for the florida/rainy bad whatever it says......
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan |
Scotchgaurd it is..!!!!!
Better work or i'll go
Since I have done it it has rained like 4 times now and still...NO WATER!!!!!! I'm totally stoked!!!
Can you tell us spyder owners exactly what you used?
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
SCOTCH GUARD -- HEAVY DUTY CARPET PROTECTOR... got from grocery store
ok so wait...what exactly do you spray the stuff onto? the seals themselves?
nope spray it on the ragtop/canvas... I just did the top but you can do the underside also..
This kept the water from getting through and collecting in the rails..
Did you get any overspray on the car?? Or did you tape it off? Did it change the color of the top such as darken or lighten it? Thanks!
Re: Re: leaking convertible top
"spyderturbo007, Did you get any overspray on the car?? Or did you tape it off? Did it change the color of the top such as darken or lighten it? Thanks!"
99 Eclipse Spyder GS |
I never bothered doing this, so I can't help you out. I just bought a beater car and don't drive her when it rains or over the winter.
Sorry!
Re: Re: Re: leaking convertible top
i have a 97 spyder that is leaking. i had a new top put on july 2004 but the seals were not replaced. the auto top place says what's leaking is the seals and it is about $1100 to replace them.EEK!!
i think i know where the seals are. i am interested in the response about just looking to see where they are distorted and manually shaping them back to normal. could you please explain? i dont know about scotchguard, does it damage the top? we have a LOT of rain here in Alabama and my spyder isnt garaged. |
