Old 09-21-2004, 08:37 PM
Geno46 Geno46 is offline
1999 Buick Lesabre Transmission Shudder
I just had my 1999 Buick transmission fluid and filter changed at 50,000 miles. Now after driving it for a couple of days the transmission shudders when I take off from the stopped position. It does not do it all the time. Any comments what the problem could be. Could the guys who serviced it screwed up something?
Does anyone know if Buick has a problem with this? Any suggestions would be greatly appreciated.
Old 09-23-2004, 05:43 AM
auto trainy auto trainy is offline
Re: 1999 Buick Lesabre Transmission Shudder
I have the same problem with a 98 olds Regency and my Trans expert said the foward clutch in the trans is faulty,mine only acts up when hot (after hyway driving) It only happens when I take off hard so I dont beat on it and its fine but I too would like to know if there was a problem with these transmissions.
Old 09-30-2004, 10:38 PM
trannyman52 trannyman52 is offline
depending on which version of the 4T60-e trans,,,, line pressure boost
is provided by a modulator or a Pulse width module,,,,,if this is not working,,,or ,,adjusted properly the trans will "slip" under heavy load
conditions,,,,but it could be the fwd clutch!!! "food for thought"
Old 09-30-2004, 11:48 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
The 99 Lesabre has the 4T65E trans. There is a known problem that causes your problem the fix is to replace your pressure control solenoid.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
