Go Back   Automotive Forums Car Chat > Kia > Sedona | Carnival II
Old 09-21-2004, 06:36 PM
allezzov allezzov is offline
Sedona rear brake shoes???
Other than a KIA dealer, where can I purchase rear brake shoes for my Sedona?
Kia is quite expensive.
Old 10-01-2004, 03:53 AM
CHVYPWR CHVYPWR is offline
Autozone lists them.
ALBANY/DURALAST BRAKE PAD/SHOE - REAR for a 2004 KIA TRUCK SEDONA
Unit Price: $19.99
Core Value*: $0.00
Part No.: 789
Weight: 5.0 lbs.
Warranty: LLT
Availability: Online: Ships within 2 business days
Store: Special Order
Note:
'78 El Camino
'86 Jeep
'97 Chevy Silverado ext. cab
Old 10-17-2004, 02:32 AM
kyle95g20 kyle95g20 is offline
Re: Sedona rear brake shoes???
in all honesty. pay the extra for the oe part. the sedona rear shoe has a funky arm that is attached to it that has some fairly strange mounting positions for the ebrake cable hardware and such. i have never had to install a set of aftermarket ones but my experience as a kia tech is when aftermarket parts are used on these cars they are often far from well made or extremely poor fitting compared to the ones that the dealer sells.
gone through so many cars i can't keep track. all i know is i have a gsr swap on the floor of the garage that is going in a teal boxy hatch.
Old 02-15-2005, 08:29 AM
MrEss MrEss is offline
Send a message via AIM to MrEss
Re: Re: Sedona rear brake shoes???
I have installed the Autozone shoes on a 2002 Sedona. Just make sure that as you compare new and old parts that you IGNORE the stamped "R" or "L" on the new parts! R is left and vice versa in korean evidently. If you use common logic as you look it all over you will find that the P-brake lever will pivot in the wrong direction. This is the only hangup I found in the whole job. the Autozone parts have worked out just fine for the last 6,500 miles.
Old 08-27-2005, 07:24 AM
ricebike ricebike is offline
+ when they do wear out again, you can turn it in w/ receipt for a free set!
Old 11-27-2005, 08:58 AM
Macrosill Macrosill is offline
I recently purchased new front rotors from NAPA. I have a few thousand miles on these new rotors and they seem to be good. I tried to purchase them at the local Aid, Pepboys and Autozone. Pepboys was able to order them and have them in a few days. Napa had em that day for less money. I would assume they would also have the pads and rear shoes.
