Old 09-21-2004, 06:35 PM
Posey88cvic4dr's Avatar
Posey88cvic4dr Posey88cvic4dr is offline
Send a message via AIM to Posey88cvic4dr
Angry Can't Get ZC Swap To Start
OK, so the motor is in and everything has been checked and re-checked. The injectors, distributor, wires, pumps, and spark plugs are all fine. The motor will crank but then shut off. If your standing in front of the car, the first header is hot, then second is warm, and the others are normal. (1st beeing the furthest on the right) Keep in mind that this is an automatic with stock LX ECU. (motor bolted right up) We know the wiring to the ECU is right, but were thinking the motor just want run on the LX ECU.
PLEASE HELP ME!!! I missed taking first place at NOPI because of this, and yes that's cocky, but i would have. I'm want to have this car ready for Scrape Fest this weekend. Every magizine you can think of will be there. Thanks for any help in advance....
4g4d4Life <--Link To My Car
TEAM CHOZEN
Old 09-21-2004, 06:44 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
atleast get yourself a pm6 man. or a pg7
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 09-21-2004, 07:42 PM
Re: Can't Get ZC Swap To Start
Will they run on a automatic?
TEAM CHOZEN
Old 09-21-2004, 07:52 PM
ef four door's Avatar
ef four door ef four door is offline
it wont run on a dpfi ecu. get urself a pg7 88-89 auto integra ecu, or a ps9 90-91 civic ex ecu. i have one if u want it. theyre kinda rare.
1989 civic lx four door, MPFI SOHC ZC powered, SOLD
1988 civic dx four door, D15B VTEC...permanently converted to obd1
Old 09-21-2004, 08:29 PM
90-91 ex auto?
TEAM CHOZEN
Old 09-21-2004, 08:39 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
that should work too, but the pg7 auto would be better
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 09-22-2004, 12:02 AM
CRXsiZCpa's Avatar
CRXsiZCpa CRXsiZCpa is offline
Go look on ebay for a PG7 Auto or PM7 Auto ECU. That is your best bet. Also check the exhaust cam angle sensor. That could be a problem too.
Old 09-22-2004, 07:04 AM
SJ-91LX SJ-91LX is offline
You can't use your stock LX ecu. I have a PG7 for an automatic that's in great shape. I'll sell it too you if you want it. PM me.
Old 09-22-2004, 07:27 PM
I went to the junyard abd swiped an ECU from a 90-93 teg. Put it in and it fired right up, but now I'm getting a code 1, 4, and 5. Since me and my buddy couldn't do anything with it I just got it towed to my local shop. I didn't want to drive because the timming sounded off and it ideled a lil under 2k RPM. Hope to have it back tomorrow, if not Friday.
TEAM CHOZEN
Old 09-22-2004, 10:06 PM
1 is your o2 sensor
4 is crank angle sensor. You prob have the wires backwards.
5 is MAP sensor
Old 09-22-2004, 10:19 PM
yea, i knew what the codes were, just couldn't fix it
TEAM CHOZEN
Old 09-22-2004, 10:28 PM
Why not? 3 easy things
Old 09-23-2004, 09:08 AM
I'm mechanically inclined.... But I make a mean pea soup
TEAM CHOZEN
Old 09-23-2004, 09:21 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Re: Can't Get ZC Swap To Start
mechanically inclined means you can fix stuff...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
