Old 09-21-2004, 05:56 PM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
is this datalogger cheap???
Uses the Palm 'n Stein software that is pre-loaded onto the PDA. The package includes a Palm IIIxe PalmPilot with 8MB of memory, Leather case, Multiplex Engineering OBDII adapter, 10' serial hotsync cable and serial hotsync cradle. timing advance, O2 voltage, rpm, coolant temp, air temp, throttle position, air flow, short term fuel trim, long term fuel trim, and MPH.
Along with being able to datalog, this can also retrieve your check engine light codes and turn the CE light off.
$107 shipped.
Is that a good price???
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 09-21-2004, 06:01 PM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
Re: is this datalogger cheap???
Sounds like a deal to me.
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
Old 09-21-2004, 06:03 PM
this is what i have to use if i want to put new injector right?
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 09-22-2004, 08:05 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
If you are talking about installing larger injectors? Then yes, you do need some type of logger. But to control the increased fuel flow from the larger injectors you need some type of fuel management (i.e. SAFC-II). Without the fuel management you won't be able to tune for the new injectors. Buying the logger will put you one step closer to getting the injectors.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 09-22-2004, 01:58 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
ya you need an SAFC 1 or 2, or DSMlink, AEM EMS or any other fuel tuning device. with the SAFC you need some kind of datalogging to tune it right [DSMlink and AEM have it onboard]
Old 09-22-2004, 02:21 PM
ok, so if I plan to put bigger injector I need to spend like $500 dollars in a DSMlink and a SAFC 1 or 2, thats to much for my budget,
http://cgi.ebay.com/ebaymotors/ws/eB...category=33597 ($280)
http://www.dsmlink.com/ordering.html ($615)
http://cgi.ebay.com/ebaymotors/ws/eB...category=33554 ($217)
Wow thats a lot!!!!!
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 09-22-2004, 02:34 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
No, you need 2 things: a logger and something to tune with. Pocketlogger/S-AFCII is a common combo. DSMlink does BOTH. It has way more features than any AFC. It's basically a simpler standalone that costs less. You need an EPROM ECU to run DSMlink, too.
Old 09-22-2004, 02:38 PM
well I should have an eprom, cause my car is a 95 gs-t so it should be an eprom, so just spending:
http://www.dsmlink.com/ordering.html ($615),
AND
http://cgi.ebay.com/ebaymotors/ws/e...&category=33554 ($217),
is enought to make the Injector upgrade
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 09-22-2004, 04:52 PM
JoeWagon's Avatar
Banned
You dont have to upgrade injectors for DSMlink, but if you are.. there's no reason to get small ones. I'd get 660's or 720's if I were you. Enough until you have a 10 second track car. Unless you KNOW you won't go bigger than 16g that is.
Old 09-22-2004, 05:39 PM
I know that, I do need DSMlink if I want to put 550's injectors. I'm not thinkig to go bigger than 16g, cause the car will be a street car almost all the time. And I think that 550's i big enought for a 16g and it still good for street. But thats gonna be in the future, Right now I only going to put a walbro 255 fuel pump and I know i don't need a datalogger for that, do you think i will need a fuel pressure regulator for that fuel pump?
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 09-22-2004, 09:45 PM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
dude if your getting this for just a street car buy this, http://www.extremepsi.com/store/cust...46&cat=0&page=
then all you need is to buy a
referbished palm m100 pda($30)
and the pocketlogger.com obd-II package.(on sale $125)
i just orderd all this, just giving you options goodluck with whatever you choose.
P.S.
This is what the alphabet whould look like if Q and R were eleminated
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 09-22-2004, 10:50 PM
Thats a very good option, i will think about it!!! Thanks 95ClipseGS-T
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
